Morimoto XB LED Taillights are HERE for ALL Tremor trucks at www.Apollo-Optics.com!
Unfortunately, I don't have those numbers. But knowing Morimoto, they directly targeted the Recon light on this product development, so I'd expect that the Morimoto light is brighter.
Any idea on when Blackfriday shipping is happening?
It is ongoing and we’ve orders go out consistently over the last few days.
I should have some more tracking info the morning and will continue to follow-up.
If you ordered the 3rd brake lights or flasher modules, those are preorder items with an ETA of late January/early February.
Couldn't squeeze those extras out of the wife and kiddos!
Can the flash module be plug and play on the factory light?
For those running the bd fog pocket how are y’all color matching it? Powder coat or paint? Is it holding up well? Thanks
About ten days from ordering Apollo Optics. Install along with boost bar straight forward. Big difference.
Today was gonna be the day. Wife and kids ordered for me as my Christmas present. Went to install, and bam. Not looking so good.. well I don't need this anyways so let's give it a go. BAM, It's Warped.... won't line up, doesn't meet the body lines, and when tightend up it pulls the top away from the fender at the corner..
@Nick@ApolloOptics can you lend a hand.
In your second photo it looks like the locating pin isn't all the way in. There's a plastic clip that goes around that pin and through the sheet metal behind the light. When I did my lights some of those clips got stuck on the pins on the old light. I also found it was much easier to pull the clip out of the metal and put it on the pin on the back of the light and then try to push the light back into place. It was very difficult to get the pins to snap into the clips while they were still mounted in the body.
In your second photo it looks like the locating pin isn't all the way in. There's a plastic clip that goes around that pin and through the sheet metal behind the light. When I did my lights some of those clips got stuck on the pins on the old light. I also found it was much easier to pull the clip out of the metal and put it on the pin on the back of the light and then try to push the light back into place. It was very difficult to get the pins to snap into the clips while they were still mounted in the body.View attachment 107489
That is what it does when tightening the bottom 8mm bolt. The 3rd picture is what it looks like fully tightened. To ensure it wasn't the wiring I removed it from the body and stuffed it inside. I even changed over to the factory plugs there is a bow in the fixture that when tightened it pulls the "clicked" in top out when the bottom is tightened. Put the factory fixture back in, no issues and a uniformed gap all the way around on vs the Morimoto.
Hey there, @Cuervo, I'm sorry to hear about your installation issues. Judging by your pictures, I would have had the same recommendation that @RS90 mentioned about the pins not being lined up in the slot when sliding back into place. But if you're positive that's not the issue, then we need to do some digging and see what's going on.
I'll send you a PM for some more information and we'll get you in touch with Morimoto's warranty team so we can get this figured out and corrected for you.
I had same issue on the fit. I popped the bottom out a bit and tightened the bolts slowly on the inner bed side. It ended up working out, but this was my reason for an 8/10 on fit. Other than that - they look 100% better.
I have stepped the turns on the screws etc no fit.
So after going back and forth with Morimoto and and me personally taking my truck over to a body shop to ensure that the issue is not on my side. Morimoto stopped communicating, wouldn't even join a zoom or video call to review the installation.
Sorry but we were able to prove it is a fixture problem NOT an installation issue. So now the question is how well the Vendor supports the products they sell.
Sending you another PM now to get this figured out. I need some supporting information from you from your interaction with Morimoto and I will escalate this.
I’m curious to know how this gets resolved.
I’ve ordered a set for my ‘22 that should ship out sometime in the next few days and judging from your post, I’m going to be dealing with the same issue.
I installed the smoked on my, '21 and they fit perfectly. The only way I could figure is if they somehow became warped.
I do remember reading your post and don’t recall you mentioning having any issues or anyone else for that matter, at least nothing that has been documented.
Correct, now I will say the little plastic insert that is supposed to stay in the hole did come out with the stock light on one side. I realized this, then removed it and re-inserted it and all went fine after that. Are you having issues with both sides, or one only?
I don’t have mine just yet.
I’m hoping to get mine sometime soon but wanted to get mentally ready in the event I run into problems.
