Well, it’s finished for now!! Everything works which is nice.
Here are the details:
I started up front mounting the antenna and ditch bracket. The windshield cowling is a pain to work around since it is rigid but got it done.
Routed the antenna cable down the inside of the passenger wheel liner. Easier to see the path laying on the ground. Then routed it thru the
@legmar Port in the baseboard.
I then tried going under the seat, but after a half hour concluded it wasn’t going to happen. So plan B , routed it down kick plate to the seat belt, then cut across behind the seat to the console. I put some blue tape in the photos to show it.
Then I took the back of the console off (two screws and a half dozen clips. I located a hole location from the back looking forward and checked clearance on both sides. I drilled a hole forward into the console (stepped from 1/8” pilot to 3/8” DIA finished hole). I put it in the pocket of the grid pattern. The antenna connector came apart making it a smaller diameter to fit thru. Turned out great!
I fabricated a fused power cable to pick up the cigarette lighter outlet.
Mounted the Midland unit to the side a my half safe using 3M VHB tape. No access to drill with the safe installed. Seems strong so far.
Completed the installation by hooking everything up and it works!
Cheers
View attachment 174456View attachment 174457View attachment 174458View attachment 174459View attachment 174460View attachment 174461View attachment 174462View attachment 174463View attachment 174464View attachment 174465View attachment 174466
