Featured
- #41
For some reason I was thinking that since I rarely see anyone using the lighter plug that it didn't provide enough amps from the fuse box.I didn’t take a photo. I spliced the adapter to the connector provided by Midland. I cut them to about 6” each, then I soldered the wires together. I used this adapter. It has a tiny red light when there is power which I like the visual indicator.
Others have been using this circuit much longer than I have. I didn’t think 10amps max was going to be a problem. So far no issues. The adapter has a 15amp fuse in it as a precaution.For some reason I was thinking that since I rarely see anyone using the lighter plug that it didn't provide enough amps from the fuse box.
That's good to hear.Others have been using this circuit much longer than I have. I didn’t think 10amps max was going to be a problem. So far no issues. The adapter has a 15amp fuse in it as a precaution.
Looks like the same for the 22 as well.I found this searching:
View attachment 177817I suspected 15-20 amp rating, this gives me more confidence.
Cheers![]()
Yes one of the reasons to go right back tot he battery is because or noise like alternator or other signal noise. I think the difference now in newer vehicles they have alternators producing cleaner power then before because of all the electronics so you can most likely get away with using the lighter plug or another power source without an issuue as long as the circuit is not overloaded. I was going to put mine in the console but think since my ham has a detachable face going to put it behind the seat and the face place in the console and see if i can steal 12 volts from before the power inverter. Since in my 24 they deleted the cigarette style plug and just have 2 usb in it.It’s good to know that outlet in the console supports 20A I will be installing both GMRS and HAM radios at some point. The one concern I have using power from the console is noise. From what I understand, to keep your radio from picking up unwanted noise from all the on board electronics you need to run power directly to one of the batteries. The battery will act as a noise filter. Not having done my mobile radio install yet I can’t comment on how electrically noisy our trucks are, but I thought I’d pass this on.
Love our KG-100’s. Did a whole install video here if you want it in the phone charger cubby.I got the KG-1000G Plus since it has a remote face. I've been using it for awhile now, it's a great little radio.
