This truck was the inspiration for my build.
Wow! That's such a nice compliment, Thanks man!This truck was the inspiration for my build.
Hopefully that exhaust doesn’t have cat piss injected in it anymore.
You were probably due for a shock rebuild. Your truck is absolutely perfect, I would keep that for the long term haul. I agree, these trucks are perfect with 37’s.I have the same set up - 37x12.5x18 Toyo AT III - Method HD beadlock + 18 offset on my 2022 - with Carli 3.5" lift (pick your shocks) it works great - I am towing like you to desert and dunes either a ATc 36'' gooseneck with SXS in back or a 24' race car trailer with car in back - no rubbing issue. If you go 37's you will loose a few mpg for everyday stuff, but towing will be similar.
I have the E-Venture set up (45,000 miles on system) and had one seal blew out at desert last week (likely from the pin weight of the ATC for 20k miles), so CJC swapeed all 4 out for the Back Country shocks while I get the E-Ventures rebuilt by SDI (figured if doing one, might as well do them all). The Back Country shocks with the 3.5" lift and Carli spring pack is a really nice package. E-Venture shocks ride even better and I love being able to go full stiff on rear shocks only when I tow - but those are not in everyone's budget.
Truck just looks right with 37's on it, you are on the right track!
View attachment 240319View attachment 240321
Hopefully that exhaust doesn’t have cat piss injected in it anymore.![]()
Lighter exhaust…I'm not getting the comment here...![]()
