Method 701 HD 18x9 Toyo 37x13.50R18 Load E Question
Wirelessguy
Founding Member 📜
St. George, Utah
2024 F350 6.7 HO Lariat Tremor Carbonized Gray
Sorry for yet another tire thread… I’ll make it quick.
Looking at pulling the trigger on the wheel/tire setup shown above. Stock suspension for now, but I’ll be adding a mild 2–2.5″ level soon (leaning toward coils or a simple shock kit, probably no spacers, and not going full Carli/King level money).
Truck is a daily that spends most of its off-road time towing a 26′ enclosed trailer with a UTV inside over rough fire roads and open desert hard-pack, think Johnson Valley. King of the Hammers is almost here, can't wait.
Main question: Any obvious rubbing, trimming, or fitment issues with this combo once leveled? Anything else I’m missing?
Appreciate the help before I hit “buy” — thanks!
IIRC those wheels have a +18 offset, you should be fine once you level the truck. I think it might rub a bit at stock height
Seen more than a few Tremors running 37x13.5 with stock ride height, so definitely can be done. Depending on how aggressive the sidewall is, I would bet that you will get some rubbing on the control arms/swaybar with a 13.5" wide tire with a +18 offset, regardless of if/when you level it. Flip side of that is if you go to a 0mm offset you're going to have to trim the inner fender liner a bit.
I’ve been told by my guy at Discount Tires he said 37x12.5R18 no issues, 37x13.5R18 it will rub on the sway bar most of the time and sometimes the fender. So he always says go level & 38”
Some numbers if it helps visualize it; it'll pull the tire in, so I would suspect rubbing is likely with the 13.5 wides.
I just installed Methods and 37x12.5 (36.5 actual) with stock suspension. Had I not had mudflaps, there would have been no rubbing.
I don’t really mind going to a 12.5, thanks for the feedback.
Looks great!
