LOW RANGE DELEMA
Alright, this should be a wrap.
Mea Culpa: I'm a victim of my own experience.
After reading about 20 FTE and TREMOR PAGE responses to my LOW RANGE DELEMA, I find I'm the culprit here. The secret is higher RPM's.
This A.M. I tried several ways to use low range in MANUAL and in AUTOMATIC modes and it came to me that I was not getting the RPM's up high enough for the computer to stop blinking and allow the shift point.
That goes against everything I know and my experience used in rock crawling. My experience has been with manual truck transmissions; 6.69:1 1st gears; 4:1 low ranges, 142:1 final drives and torque all the way down to idle. *see below for the list of rigs.
Our 2001 Dodge Cummins (NV5600 manual trans, NV 241 HD manual T.case, beefed up 35 spline Dana 60 and 80 axles with True trac 4.10 diffs) would pull near the top of its torque at 700 rpm without stalling on even the steepest grade. This is control moving over rocky ground)
My 1982 Jeep CJ-8 had a 4.4L Jeep engine redesigned to maximum torque ( bored .060"; heavier flywheel; max torque bump stick) pulling mightily down to 1000 rpms with Dana 44 and 60 axles with air lockers front and rear. I would never use low range at as high an RPM as the FORD S.D. needs to shift. Now the idiot light comes on:
On our gravel lane I came to a stop and put it into "M" for Manual and tried to go to 4Xlow, whereby the pop up notice said shift to Neutral before this can happen. I did that and pulled the stick back down to "M". Proceeding with somewhat higher RPMs I moved the toggle + & - up to 2nd. No more blinking and it moved smoothly right into 2nd. With this new found roadmap I kept toggling up the shift points all the while using more pedal and RPMs getting all the way, one at a time, to 6th gear. This is all I need.
Now for 4Xlow range AUTOMATIC.
I used the same format for AUTO-LOW RANGE.
Put the shift lever into "D" for drive.
Rotated the 4WD knob to 4XLow range, whereby the pop up notice said shift to Neutral before this can happen. I did that and pulled the stick back down to "D". Now the gear light showed 2nd gear to start. The computer will not allow you start in 1st gear-AUTO. Proceeding with somewhat higher RPMs I went through all gear sequentially up to 6th, whereupon I said that's enough for me. For some with a heavy right foot, the trans may skip-shift up the gear ladder.
Now that I'm retrained for 2020 use this should be the end of my LOW RANGE DELEMA.
Thanks for listening.
Case closed.
jefe
Here's the list of 4-byes we’ve owned:
1949 Willys Ute Wagon with Chevy 265; 283; V8, SOA, 5.38’s and Studebaker overdrive.
1966 Toyota Land Cruiser FJ-40 4.11’s with factory PTO winch and matching jeep trailer
1970 Toyota Land Cruiser FJ-55 4.11’s with Chevy 307 V8, Power Lok, and Warn 8K winch
1973 Jeep J-4700 Gladiator 1-ton pickup. 4.10’s sturdy drivetrain.
1980 International Scout Traveller, 118" w.b. with factory Nissan 3.3L turbo diesel, SOA 3.73’s and T-19/Dana 300. Dana 44’s both ends; trac locs
1982 Jeep CJ-8, torque built 4.4L, SOA, 37’s, 4.88’s, D-44/D-60 air lockers both ends, NP-435 trans, Dana 300 with 4:1 gears, on board welder, Warn 8274 winch with only the tub and most of the frame stock original. About a dozen roll overs and 160K hard, slow miles at; 130-142:1 final drive in lo/lo.
1989 Jeep XJ, Renix 4.0L, I-6, Limited; 3.55’s trac loc.
1990 Jeep XJ, Renix 4.0L, I-6, 3.55’s (rolled this one off a cliff in Telluride, CO)
1999 Jeep XJ, MPI 4.0L, I-6 with True Tracs both ends, a 3" lift; 3.73’s our winter car.
2001.5 Dodge 2500 4x4 Cummins HO 6 speed manual; HD T-case with True Tracs, both ends, 3 inch lift; 15K pound Warn winch.
2004 AWD Nissan Murano SE package with the maximum traction additives.
2007 Kioti 4WD, 35 HP, 3 cyl, N.A. diesel tractor with foot pedal rr locker and turning brakes.
2011 Jeep Grand Cherokee Limited with actual low range.
2019 Subaru Cross Trek with X-mode.
2020 Ford F-350 XLT SRW SC SB 7.3L gasser, 4.30's, rear e-locker factory 12k # Warn winch.
