- Sep 14, 2020
- 21
- 49
- 2020 F-350 XLT 7.3L gas
- 2001 Dodge 2500 Cummins TD 4WD 6 speed manual
This is a question for any 10R140 (10 speed auto trans) with transfer case guru or transmission service tech.
I asked this on the FTE site with no replies.
We bought our 2020 Ford F-350 XLT FX4 4WD SB SC 7.3 gasser 4,30 gears off the lot as there were no Tremors available.
I figured it had 10 gears in high and low range. (It does have the 5th-wheel prep package, if that makes any difference.)
Now the dilemma:
I have only 1st gear in low range MANUAL. If I try to speed up it will just blink but not respond to the gear manual toggle switch on the control stick.
I have no "Rock Crawling" gear. The 2021 had that.
In low range AUTOMATIC I have only 2nd and 3rd gear no matter how slow or fast I go. It will not go up or down beyond those gears.
The service writer at the Ford dealer said the computer will only allow what it will allow. He said it was to save the trans and T-case from being used too aggressively.
He also said I did not have the Tremor Package which has a different programming for the trans and T-case. For a wad of cash I could have my SD re-programmed to allow more gear choices.
*Do you have more LOW RANGE gears available on your Tremor than 1st in MANUAL, and 2nd and 3rd in AUTOMATIC?
What say Ye, O' wise ones?
jefe
__________________
2020 Ford F-350 XLT FX4 4WD SRW SB SC 7.3L Gas V-8, dual Alt/batts, E-locker 4.30's 4190# payload; 7243# curb; Bilstein's, Rancho's, Stable Loads,12K# hidden winch, 2020 Northstar Laredo SC, 12v fridge, cassette, solar
Now the dilemma:
jefe
__________________
