No limits fabricationTurned out amazing! I was hopeful they’d have a sale for Labor Day to snag them….who did you order through?
Good deal! Is it necessary to replace the stock upper filter anymore if the upgraded lower filter has a better micron rating?For anyone that does the lower HSM kit.
I can confirm the Donaldson P553203 which is a superior filter at 3 microns absolute instead of 10-15 like the cat filters works with the HSM lower. You can also install P569758 bowl so you can see the fuel and if there’s any water that needs drained.
The 3 micron rating is better than the upper stock filter at 4 microns.
Also if you do the upper HSM kit.
I can confirm that Baldwin BF46228 fits the HSM upper kit and offers superior filtration compared to the BF7967 at 4 microns absolute vs 4 microns nominal 15 microns absolute. The BF46228 is just a little longer maybe half an inch.
Maybe not for better filtration but to get rid of the plastic filter. The filters aren’t too expensive that I plan to change every 10k. If the lower gets clogged sooner then I’ll adjust timing. As long as you still have good pressure and flow it can’t be over filtered and even though the upper is 1 micron higher it should still be catching some debris.Good deal! Is it necessary to replace the stock upper filter anymore if the upgraded lower filter has a better micron rating?
As with any mod a crappy dealer could try to use it as an excuse but I doubt it would be an issue since it’s offering far superior filtration than stock.Any warranty issues with this upgrade seems if they filter better it shouldn't be an issue.
That was my thoughts thanks for the reply.As with any mod a crappy dealer could try to use it as an excuse but I doubt it would be an issue since it’s offering far superior filtration than stock.
blackmarketperformance.com
17-24 6.7 Powerstroke REAR Cat Fuel Filter Adapter
NOW AVAILABLE 17-24 6.7 Powerstroke REAR Cat Fuel Filter Adapter Completely remove the cheap factory plastic fuel filter housing on your 2017-2024 6.7 Powerstroke while adding better filtration with a more AFFORDABLE CAT Fuel filter. Add our Front Housing for a FULL Cat Fuel filter setup! BMP...blackmarketperformance.com
Looks like there’s some competition for the lower filter now….
