HS Motorsports lower fuel filter upgrade?
Me either. Hate the sock into old housing idea.
might be the only option for me if I run the S&s
Lol, I thought of that sock as a beer koozie when I saw it.
What question did you have for them? I can reach out or maybe help
Questions I asked them:
"Hi, I'm interested in your 6.7L Powerstroke lower fuel filter upgrade kit, but I had some questions before purchasing. In your SKU 121006, you have three variants; I will have a shortbed, but I noticed you also offer a shortbed with aftermarket fuel tank option. Since I plan to buy the S&B 60 gallon tank eventually, can you confirm it works with this tank? Lastly, will this variant work with the stock OEM tank since it may be several months before I can acquire the S&B tank. I don't want to have to purchase two kits if one will work for both. Your website doesn't describe the difference between variants.
Thank you!"
Thank you!"
yeah I canโ€™t help there lol. I was actually wondering the same thing incase I upgrade down the road.
Thank you!"
I asked them the same question.
The instruction manual seems to indicate you get brackets for each scenario in the kit, but don't know why they would have 3 variants if that was the case. Wonder if hose lengths are different. Not good to not explain.
Agreed. Probably still going to buy both of their setups since there isnโ€™t any competition for my needs.
I do not like their koozie implementation on the upper bowl delete.
Nope me either. Wish someone would do a mount like bsm just further towards the passenger side.
Or SPE didnโ€™t suck.
Probably could fab something up, since I want both the BMP upper bowl delete and the gen 2 CP4 disaster prevention kit.
@Rjp4419 HS Motorsports got back to me today with the answer:
Their summary, essentially, was do not buy the stock version if you have any plans on upgrading the tank later. Buy the aftermarket tank variant now and it will work with the stock tank without issue.
The standard 122006 works with a stock tank. The 122006-AT is to be used with trucks running aftermarket tanks like the S&B you are looking at getting. If you are planning on eventually getting the aftermarket tank but want to get the lower filter conversion first, get the aftermarket tank version.
Was just about to tell you they got back to me.
I appreciated their apology in the email. For sure buying it now.
Please post pics once your fuel filter upgrade kit arrives.
@Rjp4419 Have you considered a vandal unscrewing the lower filter by any chance? I just thought of it this evening so I'm reconsidering my purchase thoughts. Would leave you stranded if someone runs off with it.
What are your thoughts? Hoses seem easy to cut as well being readily reachable.
How many people do you go out of your way to piss off? Serious question. Or do you live Chiraq?
Like the earlier exchange we had. What is the likelihood of occurrence for all the issues you are trying to mitigate? You're going to wind up with a SD that looks like a fucking MRAP listening to what you're worried about (everything). I'm not trying to dunk on you. I'm actually asking.
Theft and vandalism is quite common in San Antonio, especially with SD trucks. Travel frequently to there and all over the state. Tree huggers is an entirely different issue around Austin (probably other cities too) contaminating fuel and DEF systems.
Fair enough. I see you wanting to upgrade the upper, and lower filter assemblies. The upper to prevent your truck from burning, which seems to be really quite rare and has a high correlation with nonexistent periodic maint. You want to replace the stock lower filter assembly to reduce the cost of filter changes (and I think make them easier). But now you're about to figure out a way to cage in the tank/filter area sufficiently to prevent someone from hacking fuel lines and or spinning the filter off on you.
If you stick with the stock filter setup, and buy them online. You'll spend ~40$ every 10k miles on filters. You won't introduce new problems to solve. The stock lower filter assembly is relatively resistant to tampering in the casual manner you spoke to above. The WIF drain plug is a cheap part to keep a spare in your truck if that is a concern.
You I think are already working on a solution for locking fuel, and DEF caps. If that doesn't work out, there are a few options for the fuel cap. The DEF problem could be solved via creative rerouting of the filler to an alternate location. Keep the existing DEF filler in place, but instead of it leading to the DEF tank have it just dump on the ground (decoy).
That seems to be a solution set that solves for likely problems, and solves what sounds to be the larger issues in your mind (people fucking with your truck).
For antitheft have you looked ravelco?
No where was that implied; in fact quite the opposite:
I was thinking of not even bothering with the lower upgrade now since the Ford setup is probably more protected than adding something on that can be unscrewed. (y)
The Ravelco is bulky and doesn't really solve anything since a wrecker will grab the truck anyways. Police mode in Forscan is good enough for me.
that didnโ€™t even cross my mind but honestly Iโ€™m not worried.
If someone really wanted to vandalize or damage the truck they are going to.
