For me personally I want to change the filters out to have a better filter. The ones available filter down to a lower micron vs the Ford oem filters.Fair enough. I see you wanting to upgrade the upper, and lower filter assemblies. The upper to prevent your truck from burning, which seems to be really quite rare and has a high correlation with nonexistent periodic maint. You want to replace the stock lower filter assembly to reduce the cost of filter changes (and I think make them easier). But now you're about to figure out a way to cage in the tank/filter area sufficiently to prevent someone from hacking fuel lines and or spinning the filter off on you.
If you stick with the stock filter setup, and buy them online. You'll spend ~40$ every 10k miles on filters. You won't introduce new problems to solve. The stock lower filter assembly is relatively resistant to tampering in the casual manner you spoke to above. The WIF drain plug is a cheap part to keep a spare in your truck if that is a concern.
You I think are already working on a solution for locking fuel, and DEF caps. If that doesn't work out, there are a few options for the fuel cap. The DEF problem could be solved via creative rerouting of the filler to an alternate location. Keep the existing DEF filler in place, but instead of it leading to the DEF tank have it just dump on the ground (decoy).
That seems to be a solution set that solves for likely problems, and solves what sounds to be the larger issues in your mind (people fucking with your truck).
For antitheft have you looked ravelco?
I feel having cleaner fuel is worth it for me. And the piece of mind if the cp4 goes bad less catastrophic damage.
