How old is too old? Tire replacement
Rhebster
Tremor Fanatic
Founding Member 📜
Little Rock, Arkansas
2021 Ford Super Duty F250 Platinum
1976 Ford Bronco Sport
I got to cleaning out the garage today (which I am in desperate need to do) & started wondering when I should replace the BF Goodrich KO2’s on my 1976 Bronco. This has not ever been a daily driver, now it gets driven couple times a month around town & even when played not been worked too hard. I quit taking to the farm or duck camp years ago when I found the comforts of the modern 4x4 to out weigh the old school cool, especially on Sundays after a long weekend hunting. It’s always having been garage kept & let’s say to my wife’s enjoy it’s always been babied. Inspection of each tire shows no cracks, no weathering, nothing to indicate concern, BUT checking the date of manufacture shows 19.5 years (April 2004). I know that a long time & tires typically are not recommended beyond 10 years hence my concern & question. I cringe to think of buying 5 tires (spare on back) showing absolutely zero sign of wear/age. A quick internet search shows it’ll cost $325/tire (33x12.50x15 BFG MT) w/o mounting/balancing for a total of $1625.
What is the case for replacing versus not? I’m pretty practical, but at that cost I can fund a lot fun things & my Superduty had my wallet for a year. My wife will consider this to be “play money” funded anyway I do this;)
View attachment 133675I got to cleaning out the garage today (which I am in desperate need to do) & started wondering when I should replace the BF Goodrich KO2’s on my 1976 Bronco. This has not ever been a daily driver, now it gets driven couple times a month around town & even when played not been worked too hard. I quit taking to the farm or duck camp years ago when I found the comforts of the modern 4x4 to out weigh the old school cool, especially on Sundays after a long weekend hunting. It’s always having been garage kept & let’s say to my wife’s enjoy it’s always been babied. Inspection of each tire shows no cracks, no weathering, nothing to indicate concern, BUT checking the date of manufacture shows 19.5 years (April 2004). I know that a long time & tires typically are not recommended beyond 10 years hence my concern & question. I cringe to think of buying 5 tires (spare on back) showing absolutely zero sign of wear/age. A quick internet search shows it’ll cost $325/tire (33x12.50x15 BFG MT) w/o mounting/balancing for a total of $1625.
What is the case for replacing versus not? I’m pretty practical, but at that cost I can fund a lot fun things & my Superduty had my wallet for a year. My wife will consider this to be “play money” funded anyway I do this;) View attachment 133669View attachment 133670View attachment 133673View attachment 133674
Since it's driven very little, i wouldn't worry about it, especially if it gets very sun exposure.
Replace asap. Why risk such a nice rig over tires. Tires can deteriorate from the inside too, which you will never see. Bad ass Bronco!
You’re fine they look brand new only way I’d be worried is if there was dry rot cracks in them
I’m in the same boat except with my Harley. Tires are 18 years old. Bike only has 9xxxx something miles on it. I opted to get some new tires and have yet to install them though after a year. 😂
Very little sun exposure.
This was my first thought. Sounds like you're also not using it to take you where getting stranded would leave you in harms way. Of course you still have a spare, too... You could always pop one tire off the rim and see if anything looks suspect on the inside. $25 could buy you some additional confidence...
Now, on the flip side you have to consider the long game. At some point they should be replaced. If it's a matter of planning out your budget and waiting for a few years I don't see an issue with that. 20 more years? Probably not.
Agree with all of this.
Another caveat I’ll add to keep using the tires is it’s only driven at low speed. So 35mph around town, sure. 55+mph to get to town (if you need to)? I wouldn’t advise it.
The higher speeds are more likely to find any faults and trigger a failure. And of course a failure at high speed is far more likely to induce other damage, including potentially a crash (especially a steer tire).
Even if you don’t crash, a blown tire can whip and cause body damage, cause damage on another vehicle on the road, etc. All of that is dramatically exaggerated at highway speeds.
Also: that is a SWEET ride!
Rhebster,
If you are only driving around town, once in a while, it probably is no big deal if one blows out. But BFGs of that era are lousy tires anyway. I would never get out on the highway with them. I warned a buddy about a set of those that weren't as old as yours, and he didn't want to believe me until one blew out, for no apparent reason, at 35 MPH on his Tundra. They are fine in the garage, but not on the highway. Plus, you are already concerned about them.
Those original KOs look perfect with the vintage bronco. I would keep them stored if you do buy new ones and put them back on heaven forbid you ever sell the bronco.
If they truck sat outside or if you took a family on long trips on the highway or hauled/towed I would replace them asap. However at slower speeds unloaded, I’d leave them alone, especially I’d they are not cracked. Coat them with wizards tires shine and don’t worry about if for another 10 years.
You could always replace them on the bronco and inspect them, and if they look good run them on your daily driver so as not to throw away a perfectly good tire.
You have a Discount Tire in your area? They can check the tires for serviceability.
If you dont see any dry rot or bubbling I would worry about it...I know what shitty tires look like..had them pop while vechile was sitting on a trailer...those look fine.
Any visible signs of drying out? Look on inside edge and outside for small cracks. Always think safety first. Personally i would at least spend the money to unmount them and inspect the inside, beads, etc. where you frequently apply tire shine is going to look much better than where it does not get it.
Also, price of tires is nothing compared to the irreplaceable value of that awesome truck. Especially since you drive it. When it goes ti the museum some day put those back on.
My 2 cents
