How old is too old? Tire replacement
It doesn't explain how long tires are safe to use, but my tire store told me that four years is the limit to sell them. So the code doesn't really tell you much about how long they are safe to drive on. But looking good, does not mean they are good. And again, older BFGs were pretty much junk tires to begin with. They have good traction, but they are not tough.
I'll jump back in here again. Tire tread depth or no visual signs of weather checking/cracking/discoloration is NO indication on wether a 19 year old set of tires are still good to drive on. Where did common sense go? I would err on the side of safety for you and your family/friends and buy a set of new tires. Then you will have the confidence while driving this nice rig any speed and any where you want too. Even a minor blow out on a front tire can cause a lot of hardship and cost ya a lot more than the price of new tires. My 2 cents. Good luck!
I have a few vintage vehicles that don't rack up a lot of miles. I just keep an eye on the sidewalls. As soon as they start showing signs of dry rot/cracking, usually around the raised letters, I start thinking about replacing them.
Some, like motorcycle tires, also get a glazed look to the tread blocks as they age and harden. You might also see cracking between the tread blocks too.
I wouldn't buy old tires, but if I have em on something, I'm not gonna replace em unless they look like they need to be replaced or they're so old I don't trust them.
All tires have a expiration date, even if they look new rubber tends to break down over time. Check this out. Look for this code on your tire, it explains when the tire was manufactured.
I get where you guys are coming from but what is your common sense based on? The 6 year guideline from the manufacturer in the link above?? Sounds like a total cya to me by the tire and auto OEMs knowing that most will get to the wear guidelines by that point, anyway.
Lots of assumptions go into that and are probably all extreme in my opinion - hard use (read: high heat cycling), no maintenance or care, outside storage with exposure to UV for their entire life, etc.
If I went to the other extreme and said I bought tires, put them in a bag in a climate controlled environment for 6 years are they now not safe to use? I think not. By the way, I know people who do this with their classic cars and haven't heard of one issue in the 30yrs I've lived in this area.
For the record, if it were me I probably would have already replaced the tires if I was driving that vehicle on the road even occasionally. Based on what he has told us about his use case, and I'm assuming that beautiful vehicle has been stored inside, he is probably far from the 6 year guideline from a safety standpoint.
So what is acceptable? 8yrs? 10yrs? 12yrs?
I'm not a tire engineer, but honestly, unless someone on here is, or has an equivalent degree/experience, I think we are just offering opinions based on our personal level of comfort.
I stand by my previous statement of having the tires removed and inspected if the OP wants to continue to use them.
  • Like
Reactions: ccw
Well for starters those aren't KO2's, they are the original KO which haven't even been manufactured in nearly a decade. Most tire shops won't touch a tire that has a DOM over 10 years and a lot of the major shops won't touch anything over eight years old anymore. While they have been well cared for and stored out of the elements I would suggest that it's time to change them out as you won't even be able to get them rotated at most shops any longer, especially if that vehicle sees any road use at all. I had many sets of those tires back in the day and many more of the KO2's, I was a huge fan and seeing a clean set like that brings back many great memories.
If it were me, I would run them. :) I just replaced my OEM 2000 year tires on my Ducati 748. I put 300 miles on it - the bike had 1700 miles when I bought it. After the 300 miles it was time to change due to wear. I try to balance common sense and risk.
The State of Vermont which is a pain in the butt for vehicle inspection does not check date of manufacture of tire. Just sayin' ;)
