Has anyone modified the B&O unleashed sub box with a better subwoofer?
I have more/less the system you have. I felt the sound deadening and block off plates did a heck of a job tightening up the bass. I stuck an aftermarket woofer in the original box along with a kicker 47KEY500.1 DSP amp. I used the kicker 47KEY200.4 DSP amp for everything else. Don't forget the PACampPro!! It's not perfect, but sounds pretty darn good. I have a bass knob installed just below the stop/start button which makes it easy to adjust on the fly. I am sure a custom box would tighten up the bass even more, but I was done spending money on it......
I've realized I didn't answer the OP's question. I didn't change the new woofer until after installing the bass amp........ Crutchfield has these kicker DSP amps pretty cheap now...
This is what it looks like. 🤔🤔
I'm right there with you because after spending 8-10K+ on both of my Raptors and then 21 Tremor with MTI dual sub enclosures with JL subs, multiple amps, NavTV Zen units, I was determined not to go down that road again with my 24 Tremor. I spent 2 days installing sound deadening material, block off plates & the Focal flax speakers. Per Jim Skaggs I gave the Focals 25+ hrs of break-in and I was pleasantly surprised, and a little blown away at just how great they sounded and how much bass they were putting out only being powered by the stock amp. Definitely not turning my hat sideways and rattling the windows bass like my previous 3 trucks had. I'm getting older and kind of over that thumping bass anyways. No one believes me when I tell them I'm running the stock amp and have no subs in my truck. I would love to find a sub that fits in the OEM enclosure just to get touch more bass.
That explains why it sounds like 💩
Does the back seat have to come out to get to it?
Nope, I bought that $25 bracket that has a lever/loop thing to release the seat lock and let it fold down. I had one in my 21 Tremor as well. Money well spent too :-)
I just found a video showing the hidden seat latch on the driver's side. Why there isn't a loop like the passenger side, I'll never know. Did you buy a Ford part with the loop?
The passenger side has a release.
This is the one that I bought for the driver's side. I'm pretty there is a loop thing on the passenger side to release to unlock it.
@Digger29
Can you give me some more details about your install? This is the type of upgrade I might be in the market for vs $10K.
For the fronts, it looks like the 3 way Focals you referenced have 3 separate components? Woofer, mid-range, tweeter. What is going where? Woofer in the door, obviously, but mid-range in A-pillar and tweeter in center of dash?
Were adapter brackets required for the speakers to fit? How did you handle the connections to the speakers? Cut off the factory connector and wire to the Focals or was some adapter connector available?
I'm not super experienced in audio work, so would like to understand what is going where and how before I start spending money and taking things apart.
Thanks.
@Digger29
Thanks.
I wish that I took pics while I was doing it. Here goes :-) I purchased everything needed from MTI. Use whoever you want BUT I highly suggest calling Jim Skaggs at MTI because he supplied me everything that I needed and other than one phone call to tech it was a fairly easy install. With the 3 ways the 6.5" driver goes in the front doors with adapter bracket, the tweeters go in the pillars with adapters, the 3.5" mids go in the corners of the dash with supplied adapters. I have the Unleashed system and I'm not sure the regular B&O or the non B&O systems even have 3.5"s in the corners of the dash. I used OEM speaker wires, and I spliced and soldered in MTI's adapter speaker wire plugs, leaving the OEM plugs taped to the wires so I can pull everything and just plug everything back in. The rear doors were super easy because the speakers just require the adapter plate and you're done. Installing the sound deadening and the 4 block off plates was by far the most time-consuming part of the job. Worth every penny though because the truck is so much quieter inside and you can barely hear the music playing outside now. All of the door rattling is gone too. Like I said I'm getting great bass with the Focals using the stock amp. They're definitely quite a bit better than the JL C3's that I had in my previous trucks. You'd expect that seeing as they were triple the cost of the JL's but still worth every penny in my humble opinion.
Thanks. I have the B&O U as well. I didn’t realize there were speakers in the dash corners so that makes sense now.
Did you do anything with the center dash speaker?
Also, did you mount the crossovers that come with the Focals?
Any new wiring required between the 3 components of the speakers?
@Digger29
@Digger29
On the center channel, I was lucky enough to be able to grab a 3.5" Focal from a buddy who builds trucks for the SEMA every yr and he had one laying around from a previous build. You won't need any additional wires for the 3 ways and because it comes from Ford with separate 3 ways and wiring for each speaker, so you'd be using the existing wires and just swapping the plugs out. You also won't need the use the crossovers that come with the Focals if you're using the OEM amp and head unit BUT if you choose to go with an aftermarket amp then you'd need use them and run new wires from them up to each tweeter. Feel free to call or text me if you have any questions at 508 243 1232 Mike
Correct me if my understanding is inaccurate as I'm about to install a dual amp setup soon. The center and two A pillar speakers run off head unit. Is that still the case if I remove the factory b&o amp?
That's a great question and my understanding is yes they do. I had dual amps and a dual sub enclosure behind the rear seat in my previous 2 trucks, but I didn't do the install. I actually had paid to have everything installed and tuned in my last 3 trucks. This was my first attempt installing speakers, sound deadening, block off plates etc, and in the big picture it was a very minor job in my opinion, and it was still a TON of work.
Just did sound deadening in the doors the other week. Friday, I'm ripping everything out behind driver's seat and sound deadening. Honestly, it's really not hard with the help of YouTube videos. It just takes time but glad I'm saving on the cost. Crazy how expensive some shops are.
I watched a ton a videos too and I installed more material, and I did a much job than the shop that has done my previous installs. It took me about 8hrs split up over 2 days.
Thanks. That all sounds simple and doable. I’m definitely going to try it using factory amp and see what the results are.
