- OP 🔹
- #41
Good luck! It's definitely a fairly easy but time-consuming job. The only issue that I had that required a call to MTI's tech guys was when I installed the 3.5"s in the dash. The drivers side required a little trimming because I have the lariat ultimate with heads up display and the dash is different on that side because of HUD, and once the adapter plates are on you need trim the screws down flush with the plate. In my opinion it all comes down to the sound deadening material and after seeing how my 2 Raptors and my 21 Tremor was done, I was determined to a better job, and I know that I did. I put as much as possible in the inner door panel before I installed the block off plates. I wrapped all of the wires with foam tape and really got a ton on the outer door panel. I'm 100% positive that if you use the same Focal Flax speakers that I used that you'll be pleasantly surprised at good it sounds using the OEM amp and the amount bass coming from the 6.5" drivers is nothing short of impressive. Like I said feel free to give me a call if you get stuck on something.Thanks. That all sounds simple and doable. I’m definitely going to try it using factory amp and see what the results are.
