- OP 🔹
- #61
Did you disconnect both battery negative terminals before messing with the BCM plugs?
My guess is nope.. No issues with mine so far knock on wood.
Tried it just now. No luck.My guess is nope.. No issues with mine so far knock on wood.
Did you find and install your brake light camera yet?I think he meant did you disconnect your battery before installing to avoid any issues like you now have, the manual states that it's recommended.
That was done too. Maybe just a bad module.I think he meant did you disconnect your battery before installing to avoid any issues like you now have, the manual states that it's recommended.
Can you post pics of the button mount and how / where you got through the firewall?I ran in through the firewall, and did a 12v relay to turn it on/off with Upfitter. The mode button is a momentary push button I drilled a small hole in the left inside of my upper glove box and flushed it in.
I would love pics tooCan you post pics of the button mount and how / where you got through the firewall?
Any vids of it moving to see flash pattern....Just got my Z-Flash module I ordered on Black Friday. It was pretty easy to install. Wired the On/Off to my up-fitter, and put the mode button in my upper glove box.
Here's a couple videos.
15 min if you know how the plugs work. 1 hr if you’re new to the BCM plug contraptions.I still have my module. Haven’t installed yet. How difficult of an install?
Got it. Thanks. I have done a lot in the past with BCM connections and upfitter switch wiring.15 min if you know how the plugs work. 1 hr if you’re new to the BCM plug contraptions.
The 15 min assumes you’re using the provided switch. If you solder it to a pass through wire and then to an upfitter switch then that will obviously take some extra time depending on your speed with electrical work.
Reason I ask I have the zflash no truck for it to go into yet.....but I'm a fire Chief wanting to use for fire callsI'll post some videos this evening for you. If you look at my very first post there's a couple videos there as well.
Wow. Super niceJust got my Z-Flash module I ordered on Black Friday. It was pretty easy to install. Wired the On/Off to my up-fitter, and put the mode button in my upper glove box.
Dude that’s awful. Have you reached out to UltraBrightLightz to seek help?OK my ZFLASH has burnt out front Led turn signal passenger front. TWICE now. Had the dealer replace the first one and they have to
Replace the whole lamp assembly. Very very costly . And as soon as I tuned in the zflash again after the brand new light replacement
IT HAPPENED again. NOT GOOD .
I haven’t had any issues with my truck, and I’ve used my Zflash on 2 trucks now.For sure would like to hear what the deal is with that... have not seen anyone else having issues to hopefully thats a good sign!
Question for those that have installed theirs already, what happens if you turn them on and you have a trailer attached? Does it flash the trailer as well or ?
