Got my Ultra Bright Lights Z-Flash Today!
No without upfitter 100% plug and play no wiring to 12v or splicing
That makes sense. The part I’m not sure on is if you can solder the Zflash power wire straight to the upfitter wire without having a 12v relay in the middle…
I'm curious how difficult it would be to splice it in to the hazard button module. That would be relatively badass and completely in line with the express function of the button.
I wondered about that as well. Now that I have been using the Zflash for a while I have found that I enjoy being able to choose between regular hazard lights and a little more obvious hazard lights. Maybe it’s the engineer in me, but I love to have options and different levels of lighting for various needs. 😄
I'm not sure if that's a good idea depending on where you live. You may very well fail state inspection. Many states have strict regulation on how hazard lights work, as well as what vehicles can have alternating flashing lights, color of flashing lights in the back, etc. You're best off not bringing the device to the attention of the DMV or state inspectors.
Random tidbit. Technically, a flashing high mount stop lamp is illegal under federal law, but it doesn't apply to our trucks because they have a GVWR over 10k lbs.
So this came today, I can’t seem to find where I put my third brake light since I moved. The second I find it this will get installed.
Can you run the remaining two S2 lights on the cargo light circuit? I have no need for chase lights but I'm pretty intrigued about upgrading my cargo lights to something massive.
Big negative, they will draw too much power.
I’m with you. I’ve been looking at the limitless version and would much prefer the hazard light button to run this. Otherwise I’ll mount an unobtrusive switch somewhere as it doesn’t need to be readily available. I don’t want to use an upfitter for this.
Perhaps, you could run a wire to the battery for power and then install a relay using the original cargo light circuit as the signal. Then the lights are signaled as normal but have access to more power.
I think I read your post accurately and you went with the UBL BCM Z-flash (not the OBD2 variant). I started installing mine but the wiring bundle is nuts down there. How did you lay your connectors so that you could get the kick panel plate back on? The "C" plug is massive and with the short wires I can't really route that one anywhere to allow the panel to get back on.
Tetris, my friend. It helps significantly if you take off the trim piece that sits underneath the glove box. It'll give you more room to work with.
Just got my Z-Flash module I ordered on Black Friday. It was pretty easy to install. Wired the On/Off to my up-fitter, and put the mode button in my upper glove box.
Here's a couple videos.
Looks great can you adjust them so the front halo lights do not alternate ... they are nasty bright .... I want to be able to use it when towing, but do not really want halos alternating or blinking.
Negative, plug and play and preset changeable modes but the "C" DRL "Halos" will still be in those patterns.
Anyone here have or find any video of installing on a 22 Ford F-350 ?
Just got the email that my 22 has been built. I plan to make an install video in February.
Welp just installed mine and now my passenger rear blinker doesn’t work 🤦🏻‍♂️
This happened to me except it was my window that didn’t go up and down. Remove and reseat all the connections. If that doesn’t work, contact the company for a replacement. (I had to)
I had no luck with it working after plugging back it. Have dealer appointment Monday.
So, when you removed the Zflash and plugged all the factory plugs in as stock it still didn’t fix the light?
