Got my Ultra Bright Lights Z-Flash Today!
I'm not that concerned as I didn't really buy this for any specific reason other than I wanted it and maybe will use it 2-3 times a year. If I had a first responder truck or construction vehicle doing public works where I needed to use the flashers daily then maybe it would rase a concern.
It looks like you do trade the cost of a 3rd BD light for the Camera Mount. The actual base is likely still the exact same.
I got my housing at over half off because I got it from their Scratch and Dent sale. The only blemish mine had was runs in the powder coat on the inside of the housing so it made no difference to me.
I know PTT is probably getting sponsorship and he’ll see more issues. I think he does put our good info, you just have to ignore some of the “commercials”.
He has one video that shows how to turn off the seatbelt reminder come and it also turns off the warning light. I have some land that I drive and don’t need a seatbelt on for that area, so that info was good for me.
Well thank you for posting the info on the seat belt chime...his sequence appears to have turned that off w/o using forscan. Wish the double honk when exiting was that easy.
Me too
Quote from site: "Super-Duty Fitment: This light will eliminate the high mount camera in the 3rd brake light of equipped vehicles."
I would fail my state DMV inspection just for that.
Did read my post prior? they made a housing to add back in your factory camera.
I so don’t need this. I did see a limitless video from PTT as mentioned - liked that as it integrates more lights. I’ll not do any of it - but you should all know I want to. 🤪
So this came today, I can’t seem to find where I put my third brake light since I moved. The second I find it this will get installed.
Just got my Z-Flash module I ordered on Black Friday. It was pretty easy to install. Wired the On/Off to my up-fitter, and put the mode button in my upper glove box.
Here's a couple videos.
What did you have to do to wire it to the upfitter? I did some lights there, but it was just the power wire and I thought when I glanced in to the package that the on/off switch was two wires? Did you use a relay or ??
You mention the mode button, is that to switch patterns?
I’m definitely curious as well what the upfitter “connection” or “process” was for you. I saw some pass through wires near my BCM but decided they were short and that using the Zflash switch in the cab was the easy and lazy way. But if I saw instructions on how to complete the upfitter setup I may be encouraged to follow suit. 😄
Just did this in my 22’ - worked perfectly.
I ran in through the firewall, and did a 12v relay to turn it on/off with Upfitter. The mode button is a momentary push button I drilled a small hole in the left inside of my upper glove box and flushed it in.
Did you get the high mount camera reinstalled yet with this?
Not yet, I can't find where I put my OEM third brake light. I'm going to check my storage probably on Thursday .
Is the relay required instead of connecting the upfitter wire straight to the Zflash power wire?
No without upfitter 100% plug and play no wiring to 12v or splicing
