If you are looking for a solution for power that does not require you tapping into the interior fuse box, look into this solution from
@NEOHIO, it provides two separate power sources for interior items:
https://www.ford-trucks.com/forums/market/1790117
If you need a 12v constant for the parking feature of the dashcam, you can use one of the small pass through wires in the passenger footwell that go into the engine bay since it is a low amp need. I would not use these for pass through wires for anything with a larger power draw, but for the parking power, it is perfect. You can connect the wire in the engine bay directly to the battery.
This is how I am powering my dash camera and my phone charger that I run up through the Bulletpoint Rubigrid on my dash - I did not have to use the fuse box so I can keep the factory cover on.
