I was trying to find out the same thing . I am always up for better filtration but I have a hard time of giving up filtration for the ease of maintenance.I don’t know what the stock numbers are trying to find that out
Agreed, only thing I’ve found but don’t 100% trust even though it’s a ford parts site they’ve been known to have messed up descriptions and infoI was trying to find out the same thing . I am always up for better filtration but I have a hard time of giving up filtration for the ease of maintenance.
This set of specifications leads me to believe this filter is for gasoline since it mentions flex fuel and has a 300 series stainless steel case.Agreed, only thing I’ve found but don’t 100% trust even though it’s a ford parts site they’ve been known to have messed up descriptions and info
Weird, here’s a different spec which states 9 micron. https://www.dieselequipmentinc.com/...i06f1wpVrIwn-2wRxPUbgcGrPN5Gr1XwtAQK-uYBYDRKpThe Donaldsons in the fleece kit are 4 and 9, straight from the Donaldson site first pic is the larger under truck filter/ws second pic is the small under hood filter
View attachment 187352View attachment 187353
Yes that is correct for the top filter the bottom filter is 4, again top under hood filter is 9micron part# p555095 the lower under truck filter is 4 micron part# p553203 you should use both kits in conjunction other wise the stock filters are only sold as a set and you’d be wasting money on an unusable filterWeird, here’s a different spec which states 9 micron. https://www.dieselequipmentinc.com/...i06f1wpVrIwn-2wRxPUbgcGrPN5Gr1XwtAQK-uYBYDRKp
It’s not I couldn’t fit the whole thing in a screen shot at the top of the page is fd4647 which we all know is the diesel filter set here’s the link https://parts.ford.com/shop/en/us/filters/fuel-filters/fuel-filter-element-p-fd4647?pdp=yThis set of specifications leads me to believe this filter is for gasoline since it mentions flex fuel and has a 300 series stainless steel case.
That definitely is a concern, I saw a video by S&S when they had an issue with aftermarket spin on filters , the DCR did awesome but it was amazing how much water/condensation and rust was found in the filter.What’s rarely talked about is when you go to a metal spin on filter it creates more of a concern for condensation = water In fuel
A vehicle that sits and is not driven normally is suseptible to condensation in many areas of the fuel system, not just the filter.What’s rarely talked about is when you go to a metal spin on filter it creates more of a concern for condensation = water In fuel
I watched that exact video by S&S, and I hold S&S in high reguard. But I am suspect about the video. They did not mention how long the filter had been in use, if it had ever been periodically drained, and other use type factors that could contribute to its condition. I have a spin off water separating filter and have never found evidence of water, much less rust or muck I saw in that video. I have S&S products on my truck, no issues. It really surprised me they produced that video with no supporting evidence as to type of maintenance, intervals etc.That definitely is a concern, I saw a video by S&S when they had an issue with aftermarket spin on filters , the DCR did awesome but it was amazing how much water/condensation and rust was found in the filter.
Well yeah I would think that’s common sense, my only point was the oem has moved away from metal filters to plastic housings several years ago for in part the condensation effects I’m sure cost is somewhere in there as well lolA vehicle that sits and is not driven normally is suseptible to condensation in many areas of the fuel system, not just the filter.
I can tell you this I’ve been running diesels for 20 years same fuel stations as well, back when I ran air dogs on everything (metal filters) I would drain my water separator once a month (which I still do) I’d almost always see a couple bb’s of water rolling around in the bottom of my drain container, more current trucks with stock plastic filter housings with drop in filters I still go to the same fuel stations and still drain once a month I have not seen 1 single water “bb” in my drain container, coincidence maybe but highly unlikelyI watched that exact video by S&S, and I hold S&S in high reguard. But I am suspect about the video. They did not mention how long the filter had been in use, if it had ever been periodically drained, and other use type factors that could contribute to its condition. I have a spin off water separating filter and have never found evidence of water, much less rust or muck I saw in that video. I have S&S products on my truck, no issues. It really surprised me they produced that video with no supporting evidence as to type of maintenance, intervals etc.
Also the plastic canister oem filter under hood has documented instances of cracking resulting in under hoodWell yeah I would think that’s common sense, my only point was the oem has moved away from metal filters to plastic housings several years ago for in part the condensation effects I’m sure cost is somewhere in there as well lol
That supposedly has been dealt with a while ago not sure exactly how long but they’ve been reengineered to prevent that, but hey I’ll take a new truck if it burns up after paying years and years of insurance with no claims lolAlso the plastic canister oem filter under hood has documented instances of cracking resulting in under hood.
Change every fall for mu no matter mileage. Best to go into winter with fresh filters.On the 6.7 Powerstroke, the dealer will often suggest fuel filter changes at every oil service, but that’s overkill. Most owners run them every 15k miles or so, depending on fuel quality. The fuel filter is critical on these trucks since the injectors are sensitive, but doing it every other oil change is a reasonable balance.
