Fuel additives [diesel]
It would appear i have killed this thread :|
So if i was relatively new to using add-ins and wanted to summarize everything above:
  • XPD/Archoil are probably the 2 more well rounded solutions for everyday add-ins with every fill up
  • If using XPD it probably wouldnt be a bad idea to supplement with some XL during the summer months
If i can do these two things and track my regens to ensure they complete each time i should have a CP4/engine that will last 900k miles :P
If i hit the lotto and go full pusher setup on top of all of that it will last 1.5M miles
But seriously - the best thing for me to do would be follow the two bullets above?
Sounds very reasonable. You might wish to look into the option of using Opti-Lube's Summer+ and XL in warm weather as a less expensive combo, that's my plan. I'm using XPD in the recommended winter dose (double the warm weather dose) by itself at the moment for the anti-gel properties.
I just ordered as well! Heres a question for everyone, what do you use to measure and pour into your tank?
I'm doing something close to what Nex is using, a small funnel and I have a straight sided measuring glass that looks like a cross between what Nex linked and an extra large shot glass. When I have most of these little 4oz bottles empty, I'll refill them from larger bottles of additives in pre-measured amounts so it will be a dump-n-go operation.
Optiube comes with two bottles to pour, measure and store it in if you order the one gallon pump bottle. Otherwise I just have a cheap measuring cup and it put that along with the bottle of additive in a bag in the bed of the truck.
IMO, I wouldn't waste your money on doing XPD and XL, the cost per dosing just wouldn't make sense combined with having to mad scientist and mix it. I almost strictly run XPD year round and summer if i am feeling poor, during the summer.
Some of us love to play the mad scientist with mixing fuel additives. Is that such a bad thing?? :love: :love: 🇺🇸 🇺🇸 🇺🇸 🇺🇸
RepairGeek said the iron in the Archoil is to help get a better burn and reduce regens. Here is the screenshot from the comments.
100% agree! XPD since new, 21 Tremor. Use my Banks idash that has a percentage of fuel ⛽️ left in the 60 gallon tank to calculate the proper amount of XPD. I put the XPD in prior to pumping, then pump the fuel. I feel you get a better mix this way. I carry three 4 once bottles that treat 32 gallons each in the driver door compartment, very convenient. If there is residue wipe clean, secure cap, no lingering odor. Just my method.
You come up with a routine that works best for you! I had no idea that XPD was so highly rated until the "Geeks" tested several additives by an independent lab! 😳 If you have been on this forum for any length of time you know most all topics are analyzed from all directions! This one I'm grateful for.
Count me in as one of those mad scientists. When the weather starts warming up and I’m not concerned about fuel gelling I will mix the XPD with XL just so I don’t have 2 bottles rattling around my tool box.
I do wonder if the test result difference between hotshots and XPD has more to do with the treat rate.
XPDs lowest dosage is about double hotshots "performance" dosage. While less scientific, this could also explain why Project Farms wear test showed different results. He was testing the product by itself, without adding diesel.
I was thinking along these lines also. If Hotshots is used in the performance dose instead of the premium dose then the results would be better ie. more lubricity, cetane, etc. I believe the test was done using Hotshots premium dose not the performance dose.
I’ve tracked mileage for 34,000 miles with Amsoil additive, sometimes all-in-one, mostly thr cetane/cleaner combo. I’m gonna switch over to Ootilube summer+ for a while and see if I notice any change in performance. Amsoil runs me about $0.65/oz. I use 12-24oz per fill up (mostly 24oz, 60 gallon tank). The summer+ is about $0.55/oz and at max dose for 60 gallons is 6 oz. So very big price difference if it performs the same or better.
Interestingly enough, first 11,500 miles, no additives, avg mpg was 15.3. Lift and 37” tires were at around 1000 miles or less if I remember correctly.
Next 9300 miles with Amsoil, avg mpg was 14.2
Next 25,000 miles, post delete and tune, with Amsoil, avg mpg has been 14.9, constantly set on +100hp setting. And I drive it spirited.
I’ll track future mileage now with summer+ and see if there’s any significant changes.
I applaud you guys for tracking your mileage. I’m way too lazy for that. As I have said I use an additive probably 50% of my fillups. I can’t tell a difference when driving so I use it just to make myself feel better and hoping the truck lasts at least 300k miles.
The only time I track my MPG is when I’m on a long road trip (300+ miles) and that’s just because I’m curious. Usually it’s to track to see how accurate the DIC mileage calculator is compared to hand calculations. So far it’s been pretty accurate. Well at least I would say it’s within about 1 mpg differential.
You are known for your spirit! Have a good day!
QUESTION???
The 4 oz bottle says on the front it will treat 32 gallons, but the chart says it takes 5oz to treat 20 gallons. I'm somewhat confused 😕.
