Fuel additives [diesel]
I have been running OptiLube XPD in the winter and Summer+ and XL in the Summer since around 2018. I've not had any issues at all. With the XPD, I've never noticed much in the way of improvements other than maybe a little quieter running engine and a very small increase in mileage. With the Summer+, I do notice about 1.5 to maybe 2 miles per gallon increase. However, it isn't the overall performance that keeps me using it but rather the lubricity. This latest report just further reinforces, for me, that OptiLube products do what they say they do.
I run Howes anti gel, but not sure if it helps. I might not live in a cold enough environment to need one (PNW).
With that in mind, should i stop using that and just switch over to this Archoil you speak off? I am running Amsoil oil with a factory filter.
Motor oil and filter play no real part in fuel additive choice.
  • Like
Reactions: Nex
XPD Optilube here too, going on 4 years
Been team OptiLube (mostly religiously XPD year round) for better part of a decade or so. Nice improvements for stubborn 6.0 powerstroke injectors. Became a believer then and have used it and continue to use it today. I buy the gallon which treats 512 and I use their two 8oz containers. I usually fill up at an 1/8th (before the light) with the 60gal tank. I’ve used summer before and it’s good too.
Are you guys using an additive at every fill up? I’m usually only doing it 50% of the time but then I rarely ever get below 1/2 tank when I fill up.
In the summer it’s Optilube summer blend and in the winter I use the XL unless I’m going to be in sub freezing temps and I use the XPD.
When I used the XPD on my old truck 2012 Chevy 2500 I noticed white smoke when I would get on the throttle almost 100% of the time. Nothing major but I could get puffs of white smoke coming out and it was only when I used the XPD. Never really concerned me but it was there
I treat every time I add fuel, no matter the amount. Just do the math for the proper doasage!!!!
With the XPD, I put 4oz in per every 1/4 tank I fill. I generally don't let the tank get below 1/2 a tank... old habit from the winters in Montana. Once I switch to the Summer+ and XL (Extreme Lube) I switch every other fill. One time at 1/2 tank I fill up and toss 4oz of Summer+ then the next time from 1/2 tank I toss in the Extreme Lube.
I run Optilube every fill up , I usually mix XDP with XL it’s probably overkill for lubricity . I started with hot shots , then ti Optilube, got drawn to try Archoil wasn’t that impressed so went back to Optilube. After seeing what Lake Speed had to say glad I went back and it looks like I’m staying with Optilube . I also run Techron Diesel injector cleaner as per Lakes recommendation every 3000 miles .
I have a hard time understanding how 30,000 psi injectors will ever clog unless the CP4 grenades.
If anything think about how poor water quality tends to accumulate deposits on your shower head.
I'd suggest it's the spray nozzle area that would collect any of the impurities in the fuel. Not to mention the burn cycle of the cylinder could be cooking these deposits on the nozzle end. Some of this is "corrected" by a fuel additive if there is a better cylinder burn. This should fall in line with the general idea of ICE motors...the better the burn, the more efficient use of the fuel, the better resulting power production.
I'm thankful to have found this guide posted on this forum shortly after purchasing my truck. From roughly my second fill up, I was using an Opti-Lube product. (y)
The XBD summer blend is economical to use with good increases in lubricity and cetene. I got .5-.75 mpg increase in my 6.7 from summer blend.
My experience mirrors yours. I used Summer+ during the warm months due to cost/benefit and having switched to XPD a couple tanks ago for the anti-gel and other winter-relevant benefits, milage seems to be just a bit lower by .75 to 1 mpg compared to the Summer+.
I bought multipacks of the small 4oz bottles for each with the idea of then buying the gallon jugs with the pump and pre-measuring doses back into the small bottles for easy fill ups. Since my grocery rewards discount only allows 25 gallons per use, I know that that's what I'll be adding almost every time. I just wait for two pixels below the quarter tank indicator and that guarantees I'll get all 25 gallons of pump fuel in to mix with the additive.
@Winterized what the hell are all you doing up so early?
Early ➡️ late. 😆
I do probably 90% of the time if i think about it, I don't keep the fluid in the truck (or bed). It's on my shelf in the garage where i keep the 8oz containers. I hate the smell and I don't like it on my hands (it's up there with bearing grease and trans fluid). Drives the sensory retard in my brain bonkers.
good news is optilube has stated you can't really overdose and you can even double the strength on XPD for better winter coverage. It is expensive to waste but I wouldn't freak out about it.
probably helps with carbon build up and soot mitigation, many high pressure direct injectors also clog. While they're not 30k psi, one could make the same assumption about a 15k psi injector too though. The water mitigation and lubricity is the big key on something with as tight tolerances as our injectors.
Hi! I was awake just too many responses to respond to at a red light lol.
False advertising?
All the talk about injector psi is really useless the main take away from the testing is the wear scar tests which is the main purpose to keep everything lubed then secondly would be the cetane boost for better combustion
this, especially since fuel is so terrible now being ultra low sulfur and probably only a matter of time before it gets dropped again. Luckily, unlike the earlier powerstrokes, at least in theory our injectors are manufactured to work with the ULSD. Cetane boost is "great" (if it's needed) but it's the lubricity, anti gel, and water mitigation that is the kicker for me.
