Interested?
  • Yes!
  • No
@BroncoHooves these don't fit the gas version correct?
Not BH but no way. The holes are different sizes.
They fit the same actually, but gas caps have different regulations, so no plans on making them anytime soon. @ccw has the only gas one in the wild for more than a year now. @MiTremor906
Confirming that I’ve been using it for well over a year, through all 4 seasons (my truck sees temperatures below 0F at the low point and over 100F at the high point) with no issues. No evap codes, nothing.
I know it won’t be sold for gas for some time, but it speaks to the quality and design regardless of gas or diesel.
@blumhagen you’re not wrong about the different hole sizes, but that’s the smaller hole down inside. That the nozzle fits directly into. The larger outer rim, that the fuel cap threads onto, is the same.
Woohoo!! Can’t wait!
Since they fit the same, there's nothing would prevent me from buying a diesel cap and using it on my gasser? Would there be a risk of it causing error codes?
They're sold as a set, so they can't be broken up. Would be green and says Diesel Fuel Only too 😅
That could work... I don't have the door badges on anymore so if I go with a green cap I can make people think I have the diesel. 🤣
23+ fuel pocket arrived and is correct. Will be working on a cap holder solution very similar to my '17-'22 design (pics below for those who forgot).
Pics from my '22:
Great job and looking forward to receiving my set !! Let me know !! I havent been on the forum in a while, I've been swamped with other things. Hope you're doing well !!
Can someone in the south Austin area with a '23 or '24 diesel truck reach out to me asap? I want to try the cap holder out, and preferably at a nearby fuel station.
As luck would have it, my '11-16 cap holder design works perfectly on the '23+ but I want to visually see how close the fuel dispenser handle comes to it with the cap placed on it.
Bump. Need someone to reach out.
Also new fixture came in and was made wrong again, so may need to push back at least a month.
Bump. I know there's '23+ owners in the Austin area on this forum. Please?
