Something you don't need in Arizona!What is NH oil undercoating?
Do you happen to have the part number for the replacement door handle ?You can get an oem color handle made that does not have the key insert. It runs $500 around my parts. Fords are notorious for breaking in through the drivers side handle, it’s a $10 mechanism on a 80k truck. Ridiculous if you ask me. My buddies platinum was broken into yesterday. ?
You can also just remove the tumbler from the handle and place a color matched insert into the hole. Also recently I know of 2 trucks that still had the factory tumbler but the thief went through the bottom right corner of the driver window and manipulated the lock pull on the inside. I have removed all 4 lock pull mechanisms.Do you happen to have the part number for the replacement door handle ?
I'm not one, normally, to rag on anyone's choices-- to each his own and all that-- but the K&N air filter should be regarded as a downgrade.In chronological order:
- Ceramic Pro ceramic coatings and PPF on grill (I have the sport pkg)
- NH Oil undercoating
- Window tint
- Headwaters Seat Covers (front seats)
- Retrax Pro XR tonneau cover
- UPR catch can
- K&N replacement air filter
- …Whipple Supercharger…???
Where do you get said part?You can get an oem color handle made that does not have the key insert. It runs $500 around my parts. Fords are notorious for breaking in through the drivers side handle, it’s a $10 mechanism on a 80k truck. Ridiculous if you ask me. My buddies platinum was broken into yesterday. ?
Concours auto salon in San Antonio I know will do this. Unfortunately down that way this is no longer even a deterrent. As the crooks have moved on to breaking windows.Where do you get said part?
Actually they somehow make a hole in the glass at the bottom right corner then with a pointed tool they lift the lock pull. They also will target the bottom left corner of the rear door and do the same. For this reason I have removed all four lock pull mechanisms. I know of 2 trucks recently that the driver door tumbler was still in place and they broke in as described above.Concours auto salon in San Antonio I know will do this. Unfortunately down that way this is no longer even a deterrent. As the crooks have moved on to breaking windows.![]()
So your doors are fully functional lock wise after removing the lock pulls? Exactly how did you remove the lock pulls?Actually they somehow make a hole in the glass at the bottom right corner then with a pointed tool they lift the lock pull. They also will target the bottom left corner of the rear door and do the same. For this reason I have removed all four lock pull mechanisms. I know of 2 trucks recently that the driver door tumbler was still in place and they broke in as described above.
Curious to reasoning?I'm not one, normally, to rag on anyone's choices-- to each his own and all that-- but the K&N air filter should be regarded as a downgrade.
They filter much less particulate than a stock filter. They will damage your piston rings over time, even when washed and oiled at the recommended intervals.Curious to reasoning?
They don't filter the air well and the oil for the filter is known to mess up mass airflow sensors. For the minor hp gain(from not filtering well) is heavily outweighed by the dirt being ingested.Curious to reasoning?
I think the people at this site did a nice job comparing several filters ability to filter air against an ISO standard. TLDR: K&N performed at or near the bottom in most of their tests.Curious to reasoning?
I'm guessing that all oiled filters are the same in terms as performance as a K&N ... S&B offers a paper filter option with their intake. On their website they state, "Both filters offer similar performance characteristics, so the decision comes down to would you prefer to throw away the filter or clean it." Personally, I'd go with the paper filter.Very interesting article.
I've been seeing a lot of cold air intakes with oiled filters, is the stance the same with say AFE, S&B, & Banks? Is it go paper or go home or are some oiled/ reusable filters better than others?
I have k&n for my civic and my main reason for purchasing was so that I can maintain it 2x as often as the replacement recommendation. Will I toss it now? Probably not. It's been in there for 100k+ miles, but I wont be putting one in the truck after seeing this.
