Rule 1: Avoid I35 as much as possible.
Rule 2: See above.
With that out of the way, these engines are solid. You've already mentioned the biggest things, using fresh fuel from a reputable source that does high volumes of sales (Buc-ee's, Pilot, etc.)
It is easy to overthink these things (I do it all the time on some topics). Always let a regen complete/finish if possible, and don't let the DEF tank get too low.
I would recommend at least this upgrade for draining water out of the lower fuel filter, because the OEM one has been known to break and can leave you in a bad situation.
A beefier, stronger fix for the problematic OEM drain valve, part number HC3Z-9J305-A. This part includes 1 drain valve & new o-rings. Fits 2017-2019 Ford F250/F350/F450/F550 6.7L Powerstroke Super Duty pickup trucks.
www.spemotorsport.com
