First Diesel - What can go wrong and how to prevent/minimize risk
Been up plenty in it already but none that high yet.
I guess the highest so far is only 5000' but it was STEEP!
Love passing the retards while towing 9000 pounds and
doing 65 at 1800 rpms!
dont do this to yourself .. The 6.7 has been around for awhile now.
I've 4, my first one was in 12' my last was 19'. I didn't have any issues. I'd have one again if I needed it. Like any modern Diesel. Good Fuel, Motor Oil, keep up on the Fuel Filters.
That's it right there (y)
Mine wouldn't drop out of 10th at 75 mph pulling maybe 7k.
Yeah, it was the container below. Could have the little measuring side empty and eventually it'd be full and leaking out the cap.
Yeah, the Hot Shot's bottle I had was also the measuring one. I'm not sure who makes the Stabil containers, but they are just better made than the others.
As a note to all, I'm going to double down on my fuel filter comment. Definitely replace them every 15k or sooner. I forgot to mention that keeping the fuel tank from dropping below a quarter tank will also extend the life of the filters. Keeping fuel clean is key to keeping the high pressure fuel system from caving in on itself. To give you an idea of how sensitive it is, the high pressure part of the fuel rail sits at 29,000 PSI when you're full throttle. A .45 ACP cartridge maxes out at about 22,500 PSI when fired. Now imagine those pressures trying to pass grime through a hole that's less than 1/10 of a millimeter. That ain't pretty, especially since it's in your engine.
What's the logic behind not letting the tank go below 1/4 full?
I fail to see how that could affect the fuel filter unless you've been
buying really crappy fuel and there's a layer at the bottom which
sloshing around somehow doesn't stir up. Now in airplanes we generally make an effort not to run a tank dry but that's more
because it's unpleasant have the pax have heart attacks.
It's the sediment at the bottom of the tank. It's probably much less of an issue nowadays.
i would replace both fuel filters every 3rd or 4th oil change.. ie @ 15,000 or 20,000 mile intervals.. and drain and check for water contamination regularly. What i do is use the same service station each time if possible, that way when you sample/drain your fuel you get a pretty good idea of their tank quality/contamination levels..
lubricity additive is a good idea if you cannot source fuel which has it already in the additive package. https://coop.ufa.com/dieselex-gold
Looks like they are only in Canada. Bummer
i am on my third 6.7 now and they have all been very reliable. i change my oil every 6ish thousand miles (i am in canada so its 10k kilometres makes it easy to remember). every time i change the oil i pull a bit out of the separator to see if there's any water in the fuel but i have yet to see anything more they maybe a quarter of a teaspoon. i put a second oil seperator/catch can on this one and in the inter it catches quite a bit of water from short trips it may be a quarter full of 99 percent water so you can see how important it is to let it come to temp on a longer drive once in a while. i hit the autostart in the morning to let the oil come to temp a bit before taking off and usually let the turbo cool off if i have really been driving hard or towing heavy before i shut it off. just do your maintenance as you should and it'll be fine. i don't recommend deleting your exhaust, i did it on an old truck and hated the truck after that. black smoke everywhere and stunk like shit all the time, walking to the truck in the early morning when it was warming up you could barely breathe with that crap mixing with the fog and the mpg improvement was not even noticeable. the 2 truck after that i left the emissions in and its so much better. depending on the season half this trucks life is idling and you would never know it was on. i do recommend getting aquainted with for scan and turning on the dpf filter screen so you know when its regaining and you can let it finish once in a while. i will usually watch it if im gonna be on the highway for a while and try to get a full one in if possible.
Yeah, that is what I am afraid of, getting myself overly concerned over nothing.
The two hardest things to overcome on ordering the 6.7 over the 7.3 are convincing my wife and convincing myself. The wife is supportive (her response, "there's always diesel during a hurricane in the gulf"). But I keep getting stuck watching these videos and reading forum posts about emission systems that hand grenade and just screw everything up. Could most of the emission system issues be deleted rather than repaired, if need be (if it came to that later in life)?
So between the SPE drain and the SPE Disaster Prevention Kit, plus all the good habits above, it sounds like I can avoid real $$$ issues, right? The plan is to keep this one to 150k.
Not anymore. You have to reprogram the ECU and PCM/TCM in addition to removing the hardware. EPA has cracked down on the shops doing delete work, so there isn't any financial incentive to do the development work.
You'll also hurt resale as no dealer worth their salt would give you anywhere near KBB on a trade (they can't sell it as-is).
I'm sure someone will chime in and disagree with these points, but this is where the current road leads us WRT emissions regulations and enforcement.
This is my experience as well.. deletes dont make sense anymore
The logic is fuel temp and aeration, both of which are damaging to your HPFP. in a system which returns as much fuel as these do the fuel in the tank will heat up when the tank gets low.
I agree 100%. I also want to add that the current generation 6.7 has grown a lot in the past decade. When it first came out, it had the emissions system bolted on almost as an afterthought. The EGR wasn't all that reliable. Everything was just pretty janky. Fast forward 10 years, the 3rd gen 6.7 and the emissions system were designed in tandem; they're meant to work together. Ford has had time to refine the EGR, SCR, etc. The industry as a whole has had time to refine everything. It's no longer something you can easily remove anymore without other adverse effects. If I had a first gen 6.7 today, I wouldn't think twice about deleting. But with a third gen 6.7, I'm fine with leaving it in tact.
I say save your money and buy a couple of the plastic OEM drain plugs instead of the SPE aluminum one. Two reasons. 1: the aluminum one is stronger. If something does break, it'll be your water separator cover. That is much more expensive to replace than the drain plug. 2: it is almost always user error when they break. I remember when I went to the stealership to order a couple of the OEM ones. I thought they'd have some readily available. But no, apparently not. They told me that no one in the service area has ever broken one before. They had to order the drain plug from a warehouse for me since they don't have have any laying around. The mechanic shop that does my oil change has the same experience. They see a bunch of powerstrokes (It's Texas after all), and they will drain the water separator on every oil change. They've never broken one before either. So basically, as long as you're careful twisting it, you'll be fine.
is this the right one for a '21? Anybody know?
2: it is almost always user error when they break. ... as long as you're careful twisting it, you'll be fine.
Somebody here posted a pic of theirs being broken upon delivery from the factory. They break. I've read several posts across different forums of guys breaking them.
You're correct that the aluminum replacement will now be stronger than the plastic cover, however when you install the aluminum drain valve you're doing it in your garage at your own leisure.
Now imagine you're a hot shotter or pulling your RV, wife and kids for the weekend and you get a water in fuel light shortly after pulling out of a fuel stop. You're in the middle of nowhere and its dark out. You're on the side of the road pissed off with a flashlight in your mouth trying to drain your fuel and you're not quite as "careful twisting it" as you put it, cause its akward and you can't get a good grip on it or whatever. You break the flimsy ass plastic tab (seriously take it out and look at it. its hilarious). You are now literally stranded on the side of the road until you can shit a new valve. Cheap insurance and takes less than 5 minutes from the comfort of your garage floor and if you somehow break the cover youre not stranded.
I'm gonna try to not type a book. I didn't read the whole thread so if I repeat some things, my bad.
1) Buy good fuel. Don't chase fuel savings to save a few cents or even 10 cents a gallon. 10 cents a gallon savings is $3.20 a tank. Not worth it. Its an 80k truck. If your income can support an 80k truck an extra $3.20 a tank won't kill you. You can't cheap out on a diesel. Find a good fuel station with high diesel sales volume and a reputation of quality fuel. Shit fuel/water in fuel will be the end of your CP4. Avoid mom and pop shops.
2) Fuel lubricity. Use an additive that adds lubricity. This debate is as old as 9mm vs .45 or Ford vs Chevy. Its cheap insurance. If the guys adding the lubricity are wrong, we've lost nothing but a few bucks. If the guys claiming that the new engines are designed to run on this dry ass new LS Diesel and don't need lubricity adders are wrong, they're out 10k for a fuel system. I like my chances.
3) Disaster prevention kit. Not required but cheap insurance in the long run. The CP4 has a reputation of blowing up. You can rest easy knowing that it will FOR SURE grenade after your warranty expires. Which is why good quality fuel and lubricity adders are important. If/when it grenades if you have a disaster kit it will save you from having to replace your entire fuel system.
4) fuel filters. Change them often. Cheap insurance. If you haven't caught on to the theme of this post, fuel quality is critical. If you want to get nuts you can get kits that use aftermarket fuel filters that have lower micron ratings and filter better. Kinda spendy though.
5) Don't run your tank dry. Fuel up at 1/4 to 1/3 tank remaining. Rolling into the station with 3 miles remaining on the DTE is not a great idea. This step leaves the fuel pumps supplied with adequate fuel
6) Don't overthink it. Definitely don't let it keep you up and night. I am a first time 6.7 owner but everything I have read says they are great engines. You just need to make a few new easy habits and you're good to go.
7) RTFM (read the fuckin' manual). The whole thing. Especially the engine section. Then do what it says. Follow the book for oil changes and filter changes.
I'm about to order a 2022 and am leaning very heavy towards the 6.7. I don't tow often (2-4x a year) but I do drive a lot of miles (20k/yr) so the fuel savings will add up fairly quickly. Also a rival dad has a 2020 non-tremor with the 6.7, so I gotta show up too.
30% of my miles are around town. 50% of my miles are out to my ranch (60mi each way, avg speed 55mph, plenty of 70-75mph highway). I am not a speeder/not heavy on the accelerator. 20% are trips (Colorado, Missouri, Arkansas)
As I understand it, some of the things I can do to help the diesel system (mostly the exhaust, the engine is a tank) include:
Good fuel (water is the enemy)
Regular filter changes (at Ford schedule) - some upgrade options here?
Drive like I stole it every so often (how often? we've got some nice hills here I could blast up on a regular basis to check this box)
What are the other maintenance and driving habits that the 6.7 require? On paper the 6.7 makes sense for me because of fuel cost and future resale. But that all requires that I don't drop 10k extra on repairs just to get to 200k. I understand there is a lot that can go wrong and be expensive, but how likely is it really? How much of the stuff that goes wrong with emissions system could be prevented or minimized with property maintenance?
If you want to see/drive a 2022 6.7, let me know. I am in Austin. Just took delivery a week ago.
