Factory LED foglamp swap to Morimoto XB.
No, the pockets changed. The Baja ones are not an OE look..
clearly the pocket changed by the light housing itself has not..
You are still wrong!
2020-21 HALOGEN. Fog Light. HALOGEN. ASSEMBLY - - FRONT. Light.
LC3Z15200A
2018-19 HALOGEN. Fog Light. HALOGEN. W/O LED. ASSEMBLY - - FRONT. Light.
HC3Z15200A
and they are AN OEM look if you use the factory XLT pockets, or just go with the diode dynamic..
garbage redacted
Neither the Baja nor the DD looks OEM. The only thing that resembles OEM would be the Morimoto XB rectangular glass one with the Tasca pocket for the newer style bumper.
:cool:(y):sneaky:
I am another owner looking for something similar to your post.
I find it odd other than Baja's, there isn't a whole lot (OEM looking).
Didn't you say from an inside source that Rigid is working on something for this lower fog pocket in your other thread? Man, that would be great if it's actually injection molded to look OEM.
Yes
Yes, check that thread.
I just posted a comment in regards to that.
BD was the first one to jump in, personally I like the BD pocket filler made of aluminum and powder coated, and it fits perfect, no gaps. I will take aluminum any time over plastic, roto molded or otherwise.
First and only for that matter, with all due respect. Certainly it's not a material (or quality) matter in this case -- to me it's been about the figure/shape. In today's world and technology, everything can be fitted to match precisely its original figure. For this case, everything has seemed to be kept on the classical style "pod" when the insert isn't such a figure. While this may be the vendors intent, this definitely isn't what I am interested in. Lastly, the price -- not questioning the quality or build of parts but the price for that fog kit replacement I consider somewhat steep and I have been told, they're not the brighest (for the price). Thusly whether its mere "hear" say... I have been patiently waiting on other vendors to release this "other" design.
Well said my friend. I have mostly Rigid products on my Tremor. (A-pillar, flush mount bumper back ups, and front bumper side rock and Ditch lights) I actually prefer Rigid, but in this case for the pockets the BD's rounded face blend much better and to me look better than a square face for this application. As for brightness and the price, I see no difference, Rigid for like products are priced close or more expensive. The BD are plenty bright and I am more than pleased with their performance. Personal preference is key, if the buyer is happy nothing else really matters.
If you want fogs that’ll melt somebodies brains out then go with Baja designs lol
Baja does, but it doesn't look OEM.
It is close enough for me and they absolutely put the factory ones to shame period. I use the brighter pro version lights in this kit. I am about performance and the BD stuff is just outstanding.
I use the pro version of the kit and hardly ever get flashed because the cut off for the BD lights is perfect.
Had them on a raptor don’t remember what model but cost me $800 and couldn’t really use them they were insane and If it was snowing or heavy fog you blinded yourself lol
Were you using AMBER? The clear lights in any application are driving lights, often mistakenly called fog lights, and you are absolutely correct, the clear in fog and snow will reflect and have a blinding affect, hence from the time I started driving was always told never drive in fog or snow with hi-beams.
Had both it was a two pod per side yes I know you don’t use highs in snow/fog lmao been driving 30+years plus I’m a lineman we drive in the worst weather imaginable in 34klb bucket trucks. The ambers weren’t as bad as the clears but still sucked in my opinion just didn’t like either of them
Ok, my setup, the amber and clear are independent of one another, enough said.
So were mine each side had one clear and one amber controlled independently on separate upfitter switches like I said I don’t remember what model they were maybe there’s lower intensity ones
In my opinion, they're about the same as factory LED.
If I were to make a change and wanted an SAE light, I'd go with the FoMoCo halogen housing and then run the Diode Dynamics SS3 PRO or SS3 MAX LED pod. It would be a nice OEM+ solution.
Also, I believe the factory LED is H10 as we use H10/005/9006 adapters for the Baja Designs Dual Fog Pocket Kit and that system works on both LED and halogen equipped trucks.
With the SS3 pro, going from a factory LED fog would I only need the newer halogen pockets? Or is there some bracketry in the back I would need?
On a factory LED truck, you'll need the OEM halogen fog light housing (the plastic part) from the 2020-2022 truck. Once you have that, you'd then purchase the SS3 Pro kit for the 2020-2022 trucks with the OEM halogen fog lights.
It comes with the below parts:
The larger brackets on either side come will fill in the rectangular hole where the halogen fog would go and gives you the mount for the SS3. Then it's a direct plug and play for the fog lights. Now, if you want an amber backlight in them, that's when you'd use the part of the harness with the pink connector to wire the backlights to an upfitter or tap them into your running lights or fuse box depending on how you wanted to wire them.
We're an authorized dealer for Diode Dynamics and would be happy to help get you setup. I've got the Pro kits in stock, in both white and amber, and both with our without the amber backlights.
Feel free to send me a PM if I can assist.
