I got the halogen brackets if you need them. I would run the morimoto ‘s. Get done good aftermarket led light pods such as Baja designs.
What are the part numbers for both of the housings? I want to get the morimoto 4 banger pods. 1000 times brighter than the stock lights. https://www.stage3motorsports.com/4...banger-fog-light-kit-ncs-white-wide-beam.html
We have the NCS and HXB 4Bangers available here at Apollo Optics. Let me know if we can help you out with some group pricing on them.What are the part numbers for both of the housings? I want to get the morimoto 4 banger pods. 1000 times brighter than the stock lights.
I recently ordered the Morimoto XB’s in amber. After reading some of the threads on here, I’m considering cancelling the order. Sounds like so many have had trouble with the electrical affecting their trucks. Curious if you’ve read the negative reviews and wondering if you did anything different in the install to eliminate the issues others are having. I hate the OEM’s on my truck!I'm sure you could possibly find something to make them function like a wiring harness with a relay or whatever that would convert the signal your OEM LED use to prevent the new ones from flickering like crazy, and/or make your controls work properly with those XB foglights. I'm not an expert but I just installed the fogs and the Morimoto headlights on my 21 F-350 a couple months back. I had the terrible dim halogen headlights and halogen fog lights and the Morimoto XB lights were perfect for my situation. I'd have to research a bit on it but I'm sure it's doable for sure.
Looks like you have oem halogens. That's what I had before switching to oem led headlights. I swapped my oem halogen fog lights for diode dynamics single ss3s in amber pro without the backlight. They work great and were pretty easy to install on a lift. They fit perfect in the oem surround.I recently ordered the Morimoto XB’s in amber. After reading some of the threads on here, I’m considering cancelling the order. Sounds like so many have had trouble with the electrical affecting their trucks. Curious if you’ve read the negative reviews and wondering if you did anything different in the install to eliminate the issues others are having. I hate the OEM’s on my truck!
Hello Harrycomes,Looks like you have oem halogens. That's what I had before switching to oem led headlights. I swapped my oem halogen fog lights for diode dynamics single ss3s in amber pro without the backlight. They work great and were pretty easy to install on a lift. They fit perfect in the oem surround.
SS3 LED Fog Light Kit for 2017-2019 Ford Super Duty
Upgrade your fog lights with our SS3 LED Fog Light Kit for 2017-2022 Ford Super Duty! Plug and play installation, with no modification needed!www.diodedynamics.com
I bought a used set from a member on here. Had to buy the ballasts and a conversion harness from black flame customs. FYI it's a chore running harness through firewall and repinning a connector under the dash. Totally worth it though for the light output.Hello Harrycomes,
Thanks for the info! Where did you get your OEM LED’s? If you don’t mind me asking, what did they cost?
I did this using the HXB white and they're fantastic. Partially wish I had done them in amber though. They're far too intense in inclement weather and lead to whitewashing everything.What are the part numbers for both of the housings? I want to get the morimoto 4 banger pods. 1000 times brighter than the stock lights. https://www.stage3motorsports.com/4...banger-fog-light-kit-ncs-white-wide-beam.html
Looks GREAT! Did you install them or have them installed? With all the negative posts, I just suspended my order for new XB’s. I need to do some more research before taking the risk of causing future electrical issues. I just called Ford to inquire on a price for OEM LED’s and was told it’s not possible as there’s no conversion kit. As of now, I’m stuck with my original halogens.View attachment 118089Still debating the tails.
It is possible, but it is not Ford sanctioned.. lots of people have done it on the forum swapping OEM halogen headlamps for OEM LED headlamps.Looks GREAT! Did you install them or have them installed? With all the negative posts, I just suspended my order for new XB’s. I need to do some more research before taking the risk of causing future electrical issues. I just called Ford to inquire on a price for OEM LED’s and was told it’s not possible as there’s no conversion kit. As of now, I’m stuck with my original halogens.
WELP…
What he said. It's def been done a few timesIt is possible, but it is not Ford sanctioned.. lots of people have done it on the forum swapping OEM halogen headlamps for OEM LED headlamps.![]()
WELP…
I have the tails and like them, i went with the red over smoked. the red is deeper than the factory red.View attachment 118089Still debating the tails.
Love the look. You have to get rid of the license plate bracketSo, I was wanting to be a bit different and get rid of the OEM factory LED foglamps (the thin rectangular one with the weird empty pocket below it) and swap them to Morimoto XB units. Have had the Morimoto XB on the 2013 F150 for over 8 years and still going strong.
I'm wanting to get the lower trim level plastic fog pockets for the bumper. @Nick@ApolloOptics
The Morimoto website says it's for trucks that have factory Halogens, so I wonder if there's some wiring shenanigans I will have to do to make them work since my truck already has LEDs.
If this isn't possible, or if you've already done this mod, let me know.
Pockets: https://www.fairwayfordparts.net/oem-parts/ford-fog-lamp-bezel-lc3z17c755aa
2020-2022 Ford Fog Lamp Bezel LC3Z-17C754-AA | FairwayFordParts.net
LC3Z-17C754-AA 2020-2022 Ford Fog Lamp Bezelwww.fairwayfordparts.net
From this:
To this: (with my red painted bumper of course)
Okay, your reply is inspiring! I’m wondering what the percentage of people with issues is to people who’ve had no issues.With the 22 Sport package, LEDs were not available. I did the install myself, in September of 21. I have had no issues. I am on the fence with the LED tails. Cannot make my mind up on the tails. Would love to see some pics on Red.
