Engine Needs Replacement
any chance you have a long standing service history with that dealer? sometimes, that will help your case with dealer/ford covering repairs if you've been spending the maintenance money with them
It's been two decades now, but my father did 42 years at the same GM dealership with about 20 of those as the service manager. They could absolutely get something like that approved with a phone call to their regional service rep from GM if they were of a mind.
I would ask. If this isn't the only vehicle you have bought from that dealership, I would politely inject that into the conversation as well. I would also state that I would be happy with partial help.
Good luck.
Good luck.
Great suggestion, maybe negotiate with Ford to cover the Engine cost and you pay the labor
If you're only 1000 miles out of warranty I would absolutely push for Ford to goodwill that. Even if they dont cover everything, I'll bet you they do something significant to help.
Aside from poor maintenance this could be do to high idle hours. The oil pressure drops very low at idle and that is where damage starts.
@Bsteiner
Curious what you have for total hours and idle hours?
A coworker just had a new 7.3 engine in a 2021. High idle hours.
Just got told my 2021 Tremor with 61k on it needs a new engine due to Lifter scoring. Does anyone know how much ford will actually help cover for the new engine. This is insane that it happen 1k miles over power train warranty.
This is a known issue with ford and some of the 7.3 engines. Ford has a CSP see this post. https://www.fordtremor.com/threads/7-3-ticking-sound.20606/post-448896 long story short, I had a similar problem at 3K over warranty. Ford covered about 60% of the repair costs. However, as it was an issue created by ford, they should cover 100% Did take about 3 months to finally get approval from corporate Ford. My out of town dealer was pleasant to work with during the process.
If you are feeling frisky write to Mrs. Balzer, the Director of Service Engineering Operations
@ Ford Motor Company
PO Box 1904
Service Engineering Operations Dearborn, Michigan 48121
I am sure she would love to hear from satisfied customers.
Also, reach out to:
Judy Charles| Business Operations Supervisor | Houston CRC
866.631.3788 x79002
[email protected]
Best of luck!
Thank you for this! I am definitely feeling frisky and will reach out to Mrs. Ballser 🤪.
Sorry you are going through this, it’s an emotional ride for sure. I went through it all, disbelief, anger, etc… finally just now at the point ready to have a working vehicle.
Wonder what a 7.3L will cost?
Im contemplating replacing a 2011 Raptor 6.2L with a 7.3L. FoMoCo retail price for a 7.3L crate motor is about $7500. Instead of replacing the motor why not just rebuild the top end?
PO Box 1904
Also, reach out to:
866.631.3788 x79002
[email protected]
Best of luck!
Best info yet!!! 🏆🏆🏆
mine failed at 95k miles
new long block from for.
not a remanufactured
& full rebuild on the transmission
i had extended warranty $100
the full bill would have been $13, 225
if you don't get any help from ford I'd upgrade to a megazilla
Don’t start by asking for ford to cover the engine while you cover labor. Start by asking for help, an open ended request.
Are you sure? Watch out for a long list of emails to follow... :rolleyes:
Ford is kind of in the hotseat right now with all their shitty QC. They are also vulnerable on the 7.3 considering the fuel pump and such. So, if it were me, I would contact Ford CC and open a case. The main point would be that the scoring didn't happen overnight and the fact that it was caught 1000 miles over the powertrain warranty is semantics.
See what you can get. If they don't offer anything, double down but offer a compromise such as Ford covering the engine and you covering the labor. Then take the labor and go to the dealer, if that was the one you purchased from, and do the same thing. Then offer to compromise and say you'll split the labor 50/50.
I know it is frustrating but try to outthink them and always use logic and not emotion. In the end, you are out nothing but a little time and effort but I can almost promise you will get something. They bank on the fact that you will not be persistent and will become exasperated and simply get pissed off and give up.
Yeah GM engines with the AFM are 💩, Ecoboost 💩, and Toyota turned to 💩 2022. All in the name of EPA.
Hopefully the CAFE tax being set to 0 in the last budget bill will do away with the V6 turbos, and the auto stop/Start.
OP I would definitely be following up with Ford TSB..buddy with a 22 had his motor replaced do to defective lifters.
i dont mind the ecoboost, had a couple of them tuned and stock (both 3.5s) I just don't understand how after 20 years of cam phasers ford hasnt made one that doesnt die.
They don't want to...Its not really profitable to design engines that run forever...They learned that lesson with 300 inline 6...
maybe just put new lifters in it or is the engine block scrap ?
The TBS was for delaminating lifters IIRC..if that's the case here its a glitter bomb going off in the block. I wouldn't call the block scrap, but it easier for Ford just to replace.
