dull thumping sound
So here is my theory...
My noise went away when they replaced the rear shocks. I could see where the plastic upper sleeve was rubbing on the shock body.
If you thunk the sleeve you will see that it resonates like the Blue Man Group beating PVC pipes. My sound was just that cheap ass plastic sleeve. I think it could be cut off and replaced with rubber boots and would be fine. In my case I am going to have the OEM shocks replaced every time this occurs because I would rather get free ones under warranty than drop a grand for cool ones. They were not leaking (yet anyway).
My truck rides fine with OEM. I spent all the money in my piggy bank to buy the damn thing so stock is going to remain until they are out of warranty.
I can only hope this is the worst thing I deal with. Other than this stupid shit, I love this damns truck!
you could see where the plastic boot on one of my rears did the same thing. I agree that was more than likely the noise. Curious how the more shock price goes up the less boots and coverings are put on them.
I took both rear shocks and bounced the rear. Noise went away. I also took the shock and compressed it and decompressed it and you could hear the clunk. I don't want to go to a Ford dealer and have them inspect for the bad shocks only to confirm it is indeed the bad shocks and then tell me to come back in 2wks or so till the shocks come in. So I'll make a call to a couple dealers and see if they will order them in and then I'll come in.
It seems like every has this issue. Wonder if there will be a recall.
I may toss some aftermarket shocks all the way around if that’s the case. Seems like this should have bee addressed already having the Tremor out for a while.
Are the folks having this issue all 20MY trucks? If so, maybe they’ve fixed it in a newer revision of the shocks. Then the replacements won’t have this issue and newer trucks shouldn’t either.
Mine is 4mons old
Mines a 2022
  • Sad
Reactions: ccw
That's exactly why I just swapped my rear shocks myself and am done with it, noise gone! Didn't want to waste my time traveling to and from dealer, leaving vehicle, etc. As I explained in a similar thread, annoying dull thump since new so I diagnosed by un-bolting bottom of rear shocks, bounced truck up/down at the bumper and noise was gone. Ordered Bilstein shocks and bolted them on............problem solved. 2.5k miles now and still thump free.
when i took my rears off my 2020 to put the kings on myself and the mechanic that helped me could not believe how easily the tremor shocks compressed. I could fully collapse them just by pushing it together with my hands on each end, there was really nothing there other than a tremor sticker. the kings i couldn't budge pushing them into the ground with all my weight
Welp, there goes that theory.
So the new theory is: there are a bunch of bad Tremor shocks in the supply chain, spread across multiple model years of production. Begging the questions: What is the failure rate of Tremor shocks overall? How many fail while under warranty? How many are bad straight off the lot upon delivery?
And how many failures are going unnoticed due to suspension upgrades?
@DrSpeed had a great explanation for this in another thread, which I'll quote here:
That’s how the shocks were designed. They are not pressure filled. They have AMAZING rebound control. If try to pull it apart as hard as you can after compressing it, you’ll find that it’s nearly impossible.
Our trucks have really high spring to rates to hold up the trucks. There needs to be little to no compression dampening - hence the ease of pushing down on the shock.
It makes sense the Kings would have significant compression damping both because of the softer springs that Carli employs and the fact the Pintop in particular is designed for high speed off-road use. In high speed the suspension will see big hits that need more compression damping beyond what the springs can provide.
  • Sad
Reactions: ccw
I brought my truck to the Ford dealer and they pretended to not hear any noise then when we agreed there was a noise they called me back later and said it is within the scope of Ford’s allowance whatever that means. I think it means I will just buy some aftermarket shocks and swap them out
Well - that's some fun wording. "Within the scope of Ford's allowance" is great!
I think there is at least two separate issues going here.
One problem is the shitty plastic sleeve that makes the thumping sound, the other is the shocks totally crapping out.
Mine were functioning fine, just sounded like shit.
The failure rate expressed here is not good. Definitely going to be looking for advise when the warranty is up.
Lazy dealer. Seeing this a lot lately as dealers shops are even understaffed. They don't want to do warranty work because they're full up on more profitable non-warranty work.
I liked that response as well, I told them I spent $70,000 on the truck and I’m not happy with the annoying rattle so don’t send it back to me until it’s gone. We will see who wins the battle. Thankfully I’m in the don’t need it for a month or so camp.
