dull thumping sound
Mine does something similar while idling. I can a hear barely audible thump sound. It's random. I figured it was the exhaust moving around.
I had something similar. I traced to bottom of front springs rubbing/thumping in lower “bucket”. I got it to stop by placing piece of thick rubber under side of spring touching bucket. Fixed noise till rubber fell out. I could duplicate the noise by turning 25degrees and slight change in elevation up front.
Now I know what it is and it does not worry me much.
You can see rub marks on bottom of front springs, they might just be this.
I have a 21 platty tremor with 11K miles on it now. The truck runs and drives great, no complaints with it except that it has developed a dull thumping sound under the truck in the last couple thousand miles. I only notice it at low speeds while driving over bumps. I think its in the front end but the truck seems to transmit sounds through the frame so its hard to pinpoint exactly where the noise is coming from. I don't hear it at higher speeds but I think it's there but masked by road noise. The dealership did a quick look at the truck (whatever that's worth) at the last oil change and said everything looks good to them in the front end. Anyone else have any experience with this or know where I should look first?
I had a thump or clunk sound. Check your shocks . Make sure they’re mounted up tight . My left drivers side was found loose.
I had it since day one on my 2022. When I had the Carli installed at 1100, it went away. Tells me something suspension related.
I’m going to investigate the spare tire
Notable that people with both 7.3 and 6.7 are experiencing this. Exhaust wouldn't be my prime thought - I would focus on areas of similarity. Front suspension, steering, etc. Spare tire is a good thought. If there is not enough preload on the hanger spring you can still move the tire around with minimal force, although it is snug in position.
From the manual:
"The wrench will become harder to turn and
the spare tire winch will ratchet or slip
when the tire is raised to maximum
tightness. You will hear a clicking sound
from the winch indicating that the tire
is properly stowed, tighten until a
minimum of three clicks are heard.
Check that the tire lies flat against the
frame and is secure."
It would be an easy to check to perform on a suspect vehicle.
So I did some investigation. And yes one of the perches is the opposite direction. And I noticed one of the springs on the drivers side I’m having issues with is not fully set in the peach. You can see in this picture it’s about an inch off the stop. I believe it’s shifting as it articulates and hitting that stop.
you can also see those colors are not matched up. Look at the yellow on the top, orange on the side and white on the bottom. On the passenger side those are all lined up with those tabs.. Like in this picture.
and like I stated in the other thread. The drivers perch is the opposite direction. The one on the driver side has the half cup towards the tire. where the picture on the bottom has the half cup is towards the engine.
'22 Lariat with 7.3 and have similar sound as well at low speed and imperfect road surfaces. Thought it was coming from spare tiring being "loose", but it's on there solid. Following this thread to see if anyone finds out what's going on.
  • Like
Reactions: ccw
Can I ask a favor? Can someone take a picture straight down the spring to the perch on the drivers side? Kind of like the last picture in my post above a couple spots. I’m just trying to make sure that the spring is set incorrectly and to see if that perch is reversed before I go back to the dealership for my appointment.
Here you go
So the driver side is different than the passenger side. I wonder why. Why would the spring not be all the way up against the perch stop like on the passenger side in my picture?
My passenger side is fully seated / indexed into the Pearce. My driver side (the previous picture) is not. By about 3/4”.
Does your noise sound like it’s coming from the driver side as well? I’m curious why it’s different.
Mine too. You guys are describing exactly what I hear.
Just got my rig back from the dealership today.
They said they isolated the noise to the rear springs. They re-torqued the spring u-bolts and the noise was supposed to be gone. It did quiet it significantly but the noise is still there, just not as prevalent.
Follow up - the noise is back as loud or louder than ever. I scheduled an appointment to get it looked at again. 2 months to get my rig in.... Bullshit
Add me to the list of having this same noise. I am not sure I care much if it's something simple and all the trucks have it - maybe I will just turn up the radio. However, every time I hear it my "that's annoying" light goes off in my head.
Welcome to the club, within the club. First rule of clunky rear end club, is ignor clunky rear end!
I was fighting this forever. It’s annoying. Mine is finally fixed. I took off the 1.5” pucks and adjustable track bar. Front end fixed but still a slight clunk in the rear. Removed the hellwig and now everything is fixed. The truck didn’t like the geometry of the front. I guess it pays to go Carli. I don’t know why the sway bar was making it clunk.
Subscribed... My 2022 7.3 Lariat has the same clunk noise under 20 mph with 3k miles on it. Sounds like it is coming from the driver front side. I will keep investigating.
Mine does this too and I only hear it at idle every now and then. Did you ever figure out what it was
