Drivers Side Wind Noise???
My 2021 is quiet as can be expected while driving a 1-ton super duty on the highway. No wind noises.
I've seen guys talk about how the door isn't aligned correctly upon delivery. Have you checked the gaps and compared that door to the others? Just a thought. My 22 does not do this.
I’ll check it out. However I tried taping the gaps on the driver door and still had wind noise like if a window is slightly open. I called ford about it, have an appointment on the 30th to check out the windshield.
They fix it?
They fix it?
Since day one, I've bitched about wind sounds and road noise in my truck. This is my 4th new Super Duty since 17', so I know it's this truck.
I had the same issue on new 22 Tremor until my Son told me that the noise was from the seat cooling setting. Sure enough, turned off seat cooling and the sound was gone. The noise is fairly prominent on my left side by the window. Easy to check by turning seat cooling off and then listen for sound again.
I’ve had the exact same issue on the top of the driver side door. No other door was making the same noise, and after two dealer visits, one tech finally fixed it by replacing the rubber seal with a new one.
Reviving this thread, my wind noise comes from the my driver door up by where the A pillar and the roof meet. If I pull on the door seal in stops and I can fit my finger in between the seal and door when shut. To sum this up my door appear to be shut tight on the bottom half and top there is play allowing wind come in around the double seal. Has anyone found a solution to this before I go crazy.
I adjusted the door striker in a tad and that took care of it.
How do you simply adjust the door striker? Doesnt the bolt auto locate the striker latch based on the hole size?
My 2023 has wind noise in both my door. My drivers door doesn't feel like it shuts correctly and tightly.
Does any one get noise from the top of the windshield? Could it be the marker lights?
I have the marker lights and don't get windnoise from them (at least not that is noticeable). In your case, I'd wonder if the windshield might have gap in the adhesive seal that is causing the noise. Hopefully that's not the case as it could result in water intrusion. It could also be the OEM antenna. I had a lot of wind noise from mine until I swapped it out for a shorter one.
I can't hear anything in my truck besides the music.
As a trick to help locate these pesky noises try using painters tape. Cover the suspected area, drive, listen, repeat until you cover the correct area. Then you can better find a solution.
The worst thing is a cross wind. There are areas in this truck that will just sing in a cross wind. Not to mention using aftermarket lights or whatever. Previous truck had some high quality aftermarket mirror lights. They would whistle, swap back to OEM orange lights...no whistle. It's amazing what a small change in the marker lens could have in that small gap of the housing.
Loosen the torz screws and tap the striker plate in. The assembly is sandwiched between the door jamb.
I would say the biggest source of wind noise comes from the trailer mirrors on a super duty. Some noise is expected, however I would tape the seems of the mirror and see if that quiets it down. Improper adjusted doors would be next. I have notice with body style, the mirror aero on this generation of trucks seem to push a lot wind into the driver's door glass area. In the summer I get bug splatters on my passenger and driver side glass. I have experience some wind noise, however only on the highway with a strong gusts.
