Interesting. I bought GM strikers and was going to go that route. Might try your method first, instead. Thanks.Loosen the torz screws and tap the striker plate in. The assembly is sandwiched between the door jamb.
This is true. I can hear whistling from inside, if i roll the driver windows down and cover the pivot seam of the mirror, it stops immediately. Definitely a source of the problem on the outside. The door can still be an issue thoughI would say the biggest source of wind noise comes from the trailer mirrors on a super duty. Some noise is expected, however I would tape the seems of the mirror and see if that quiets it down. Improper adjusted doors would be next. I have notice with body style, the mirror aero on this generation of trucks seem to push a lot wind into the driver's door glass area. In the summer I get bug splatters on my passenger and driver side glass. I have experience some wind noise, however only on the highway with a strong gusts.
Just got my F250 ‘24. Hearing something I would call ‘white noise’ from the passenger side. Thought I had a window open a crack. Starting to look like it might be a common noiseFunny, that’s where all of mine comes from also.
