Dilemma between FX4 and Tremor
Thanks all for the feedback. Super helpful. Im in the stages of looking at window stickers and looking for a sweet end of year deal in the localish area. So TBD what I find. It sounds like theres some not as advertised perks to the Tremor. Ill have to find a dealer with both on their lot to try them out.
I speak in Diesel.
Why would you waste money on a super duty with a gas motor?
Because the Raptor comes with an ecoboost.
Go the FX4 unless your "eventually" is way out.
Where the fuck are we talking about a raptor?
Why are you even bringing up the ecoboost?
If you’re going to respond, at least make sense.
The main driver for me is the front differential as there is no aftermarket options currently and I have already reached out to several who say they have no plans.
What I also like is you don’t get stuck with power running boards (the Raptor/Tremor ones keep rock chips and door dings down) and gets you 18”s with decent tires (I know people hate them but this is my fifth set of Duratracs and fourth in 285s) as well the lift is stock. OEM shocks outside of the Raptors are just that so good/bad is indifferent. The trail turn assist is cool.
Maybe if I put it into language you can understand.
1. Man want truck. Carry many woman. Go fast.
2. Man buy Raptor with 6.2l. UGGG!. Good engine. Man happy.
3. Truck break. Man sad. Man want new truck.
4. Man buy Raptor with ecoboost. ugh. Bad engine. Truck break too soon. Man sad. Man want new truck.
5. Man buy Raptor with ecoboost. ugh. Bad engine. Truck break too soon. Man sad. Man want new truck.
6. Man buy Raptor with ecoboost. ugh. Bad engine. Truck break too soon. Man sad. Man want new truck.
7. Man want new truck. Raptor still have ecoboost. Man sad. Man too poor for Raptor R. Man sad. Man buy Godzilla Tremor instead. Man still wait see if sad or happy. Ford too slow make truck.
Question: "Why would you waste money on a super duty with a gas motor?"
Answer: "Because the Raptor comes with an ecoboost."
If you are going to swap to the earlier Super 60, do rock sliders, (obviously take off the air dam), lift, wheels and tires asap then yes; just order the lower gears, rear locker and get Forscan to add the features. Who cares about FX4, just get 4wd and get aftermarket skid plates.
I have always been an incremental guy. However I will say on my Ram I had front/rear lockers and hidden winch that were far better to aftermarket despite doing a complete suspension and wheels/tires.
Time to take your medicine.....
I don't think this guy realizes what forum he is in.
I guess the counter question is: Why would you waste money on a 1200ft lb torque engine on a SRW Tremor with offroad suspension? Can't put that shizzle down on the dirt.
Anyway... enough pissing in this guy's thread.
My advice having recently gone through the same process... If you are going to suspension swap go the FX4 and cut the check book loose. You don't lose much. Front diff is the only real loss
They do pretty good as dual purpose trucks, towing and then air down to hit some trails. I really like the power towing and the trail assist off-road. Oddly enough I have needed the LSD/Locker more towing trying to get/in out of camping spots
No one mentioned sway bars, Tremor doesn't have a rear one and front one is apparently lighter than Fx4. That would translate in more body movement on Tremor. Some people don't like it so test driving both should help you with that decision.
I was excited about front limited slip diff. Ended beached up in wet snow twice. All wheels were spinning getting the mud all over the truck. FX4 would have one corner cleaner out of that situation .
I don't see it as an advantage anymore. Rear locker, good tires and tow rope is all what most of us need.
If you don't buy the Tremor, you can't be a member here! Absolutely not, no way! No meetings, no forum discounts and no feet pics. Just buy the Tremor and you'll realize the extra value.
And please, please, don't lift it and put bigger tires. That's so stupid! Just leave it as it is. Ford designed these trucks with precisie geometry, physics and algebra so why questions their judgement!?
Haha. Perfect! Thanks. Yea, I am searching Tremors trying to find a good end of year deal.
When I bought my FX4 (2022) the Tremor was on hold. I did exactly what you are considering. I bought the FX4 and lifted it (level really) and put on 35's. It's been exactly what I wanted. The only thing I miss is the locking front diff. But to be honest, I haven't been in a place that I couldn't get out of because of it, so it hasn't hurt me... yet.
Front LSD was key for me. Not possible to add aftermarket at this time afaik.
If somebody made an air or electric locking front, I would have been ok with an FX4.
Everything else can be worked around or added.
Even them Catahoula, LA Levee chicks with the webbed toes!
Freebie
Ford wouldn't make/sell me a Supercab Tremor so decision was made for me. I bought F250 Lariat FX4 7.3L, put on take-off Tremor 18" wheels to replace the 20" it came with, put on with my brand of choice 285/75R18 tires, replaced running board brackets with shorter ones to tuck up running boards, and trimmed front air dam without even taking it off the truck. Had Ford/warn winch installed.
I drove it like that for two years with my slide-in pop-up pickup camper, to gather real world data on deficiencies, and knew I didn't want to automatically throw on Carli kit or similar. Informationally, camper is on fulltime. When loaded for a trip with two of us in the cab, CAT scale shows about 2,400lb of payload (our F250 has 3,195lb total payload capacity).
Ended up replacing 4,800lb FX4 front springs with 5,200lb tremor springs (gained 1.5" lift; 1" from extra spring length and 0.5" from higher spring rate), added a General Springs 1,224lb add-a-leaf (total spring back F350 SRW equivalent) and Tremor rear block, removed overload springs, added FOX 2.5" diameter Performace Elite shocks all the way around, and completely removed the front anti-sway bar (there is no rear).
Very happy. Will wear out my current tires then replace with 37s.
One thing I really like about the tremor (not sure if the FX4) has it is the Torsen limeted slip front diff. A slight press of the brake pedal when the fron traction tire slips and the front is locked up suppling power to the opposite tire that’s not spininig
The Super Duty Tremor has a limited slip front differential, but it’s not a Torsen. Those are on the high equipment level F150 Tremors. The method described still applies though.
