Device for rear seat release
Quick google search is showing Kynthax as a chinese importer/knock-off company.
I went with BuiltRight. It may be more, but they are the originator of the design and have made a few revisions over the years.
I was placing an order for the dash plate anyways.
Ejection button with rocket propelled seat. Also, builtright all the way.
I just used a key ring and a small pc of coated cable with a couple aluminum crimps. Then looped it up by the headrest. Must be into for like 50 cents at this point. LOL
Looking at getting a device to release my rear seat back. Should I go with BuiltRight Rear Seat Release which adds to the stock release or replace the entire bracket with something like Kynthax for half the price?
Go with Built Right. Great company, quality second to none. Very responsive to any issues as well.
Builtright here. As I get older, quality parts and instructions are more important than price and they did great on both. If I get Molle Panels it will be from them.
Builtright with the red strap. Some SD's have some sort of carseat strap near there. Fortunately, I predicted this and purchased the red. Works fine.
Not to derail this thread, but does anyone else have to "reset" the BuiltRight clip on the small metal pin each time in order for it to close? For some reason, I have to slide mine down on the round metal pin everytime i use it, or it will not latch properly. I even bought a second one, and it does the same thing. It is not an issue now that I know what to do, but it was driving me crazy until I figured this out.
sometimes.
Not to derail this thread, but does anyone else have to "reset" the BuiltRight clip on small metal pin each time in order for it to close? For some reason, i have to slide mine down on the round metal pin everytime i use it, or it will not latch properly. I even bought a second one, and it does the same thing. It is not an issue now that I know what to do, but it was driving me crazy until I figured this out.
Yes, dammit. I deal with it. But figured out its much easier to unlatch the bottom and hold it about halfway up while locking the seat back up. YMMV
Given it helps add .025cuin to the storage area....okay....spend what you want.
For me the BuiltRight(if possible) strap was WAY TOO short to even have a useful purpose. Once installed the strap was barely visible, and had such little of the "pull tab" to use.
I called BR asking if I got the right part for my truck....they just shrugged it off.....really???:oops::oops:
Anyway...for my truck the space wasn't much. IF your particular truck has a bunch of space go for it.
:cool::cool:☕☕🇺🇲🇺🇲🇺🇲🇺🇲
I cut the strap off and put a longer one on. I keep the fuel treatment back there.
My home made BuiltWrong release has been working fine for a few years now, cost me $0 and about 15 minutes with some items I had laying around the shop.
I’ve used my built right pull strap like twice, for whatever reason my seat doesn’t align up very well and putting the seat back is a PITA to get it to perfectly lock in
@thatdood I thought the same thing until I learned the secret handshake (at least for my truck).
Do these two things and see if that works:
1. You need to adjust the horizontal latch bar on the truck side - Slide it up about 1/2" (test different positions)
2. Slide/move/push the Built Right release plastic piece that captures the metal latch pin towards the bottom of the seat until it clicks, and unseats from its locked position.
I believe two things are happening; The bar cannot slide into the lock because it falls down into the wrong position, and the latch can not fully close because the Built Right release prevents it from rotating properly.
When I do these things I can close my back seat without any unusual force.
Hope this works for you.
The trick is always raising the lower cushion up before pulling the builtright (or similar) seat back release. Then when you want to raise the seat back and lock it, lift the bottom cushion and the seat back together and put a little force into it. Should work every time, as this ensures the pin on the back wall is perfectly aligned with the catch.
I made my own release with an axle hat nut, 2 hole corner brace, and short length of paracord. The loop sits just above the top of the seat back for easy access. No permanent modification or disassembly of the latch mechanism.
