I have a spare BuiltRight I can send you. Just give me your address. DM if desired.
Thank you for the offer, just a day late, I just ordered oneI have a spare BuiltRight I can send you. Just give me your address. DM if desired.
You da man!No worries. Had someone else DM me so it will still go to a good home.![]()
OK, here it is again, I wrote this up many years ago, here it is with updates. So many good suggestions in here, any of the methods work. This is to help make the decision on which way you may want to go and some options on latching the seat back into position. (The biggest complaint)Not to derail this thread, but does anyone else have to "reset" the BuiltRight clip on the small metal pin each time in order for it to close? For some reason, I have to slide mine down on the round metal pin everytime i use it, or it will not latch properly. I even bought a second one, and it does the same thing. It is not an issue now that I know what to do, but it was driving me crazy until I figured this out.
I made a similar jimmy rig. small zip tie to keep the ring attached to the headrest and let it dangle behind the seat..... Retail offerings are way over engineered.I just used a key ring and a small pc of coated cable with a couple aluminum crimps. Then looped it up by the headrest. Must be into for like 50 cents at this point. LOL
Yea I may have used it the 10 times when installing it to make sure it worked.I made a similar jimmy rig. small zip tie to keep the ring attached to the headrest and let it dangle behind the seat..... Retail offerings are way over engineered.
Or, my GF has small hands (dad always told me to only date women with small hands ) and could reach the latch. Since adding my disconnect I've used it ........ zero times.
