Debonnaire Build has Begun!
The name seems like it wouldn't fit the space nicely. If you can make it fit and not look out of place do it but don't force it, the logo alone is nice.
I was thinking I would have the put the name across the top, the guys at the wrap place is suppose to be trying a few different layouts and send to me.
Ok everyone, need opinions. So originally I was going with the Fuel Zephyrs 18x9 with a 37x12.5 ridge grappler…. The original suspension upgrade was the 2.5” carli eventure … I have since changed the 2.5” to the 4.5” … so I was thinking about changing to the 20” fuel zephyr with the 38x13.5 ridge grappler. I think the tire will fit the well better and the sidewall ratio is still very similar from the 18” rim and 37 vs the 20” with 38 … also the load rating on the 38x 13.50 on the 20 is higher than the 37 x 12.50 on the 18.
I personally think that the larger rim and tire still gives me a good sidewall ratio for off-roading and I get the higher capacity tire.
Opinions greatly appreciated!
I'm betting you've seen this, but if not it's worth checking out as it mirrors your build very closely (Dan's personal truck from Carli).
Regarding wheels, I'm going with the Fuel Coverts in gloss black with a blacked out carbonized gray build. Really like the Zephyrs but think the small detail gets a bit lost on these big tire builds.
My tire size will be 37x12.50r18 as 18" tires were the only size I could find (literally no 17s that I could find in stock).
Thanks! Im going with 37x12.5r18
Ok, something I’m wanting to add to my build but don’t know where to start. I’m wanting to update my exhaust. I however do not want an overly loud truck nor do I want any drone in my cab. I want better performance however. I his is my first diesel and I am not familiar with what the best options are for this engine. I looked over the forums a
You're not going to find much in the way of improved sound or performance. The stock DPF eliminates those options. @ftchmup can attest to that. He added the 4" or 5" exhaust. I think it's just DPF back.
Ok thanks, if it doesn’t help no reason to do it then. Good way to not spend anymore haha!
yep, looks different and I like that, but no difference in sound..........
Did you do anything aftermarket to make the 37s fit?
Update: was told all parts for the Carli Eventure is in except the shocks. Couldn’t get an actual date for when they thought they would be in. So that’s all I am waiting on.
On another note: will 37/12.50 on an 18 rim with +1 offset fit factory height?
I’m sure it’ll rub pretty good. Could always have all the parts installed and throw on some 4” bilsteins until the carli shocks come in.
I'm sure I'm late to the party on this and you've probably figured it out. The only 38" option in 18s, unfortunately, are the Toyo M/Ts. Great tire, but they get loud quick--and I do enough highway driving to justify not getting them. The Nitto does not make a RG in 38x18. To further mess things up, the RG in 37 x 13.5 x 18 that I wanted have been on national backorder and I wasn't willing to pay the markup some of the online retailers were charging. So I settled for the 37 x 12.5 x 18. That's the only part of my build I had to "compromise" on but I figure I can change those at some point. Good luck!
I went
I went with the 37/12.5. Are you overall happy with the look? I agree the yo-yos are to loud. I to also put a lot of miles on. Did 50k this past year.
I went
I'll let you know this week! If everything goes well, I should be picking the truck up tomorrow afternoon. I did take a pic of the new setup in front of the stock setup and it looks pretty good--of course, not a good representation as opposed to being mounted on the truck.
I wanted to do bronze wheels, but couldn’t make myself do it!
