Debonnaire19
- Joined
- Dec 29, 2021
- Messages
- 406
- Reaction Points
- 595
- Location
- Great New Orleans
- Current Ride
- 2020 F150
- First Responder
- Critical Care Flight Paramedic
Truck Accessories 2022 F350 Tremor Package 6.7L
1 0.00 0.00T Truck Accessories E-Venture System CS-FLC-05 Front Leveling Coils CS-FEV25SPKG-LVL-05 Carli/SDI Custom Tuned 2.5" Shocks, Harnesses, ECU, Touch Screen, & IMU CS-FORDBBL-LVL-17-F Front Brake Lines CS-FCASTERSHIM-2.5 2° Caster Shims CS-FBDF-2.5-17 High Clearance Bump Stop Drops, Front CS-FATB-17 Track Bar - Direct Fitment to Carli Leveling Lifts - Replaces Immobile Factory Sway Bar with Custom Torsion Bar - Huge Ride Quality Improvement - Includes CS-FEL-LVL17 Drop Brackets and Sway Bar Links - Fitment: 2017+ Ford F250/F350 4x4 - REBUILD PARTS SKU: CS-FFSP-LVL-17-HD - Block eliminating, Full Progressive Spring Pack - Heavy Duty Full Replacement Leaf 1 11,730.00 11,730.00T DATE ACTIVITY DESCRIPTION QTY RATE AMOUNT Springs designed for those with constant 1,000lbs in the bed - Includes new U-Bolts and Rear Bump Stop Drops - Provides a 1", rear high stance on Matching 2.5" Leveling Suspension Systems - 37" Tire Fitment - Fitment: 2017+ F250/350 4x4, 3.5"-4" Axle Tube SKU: CS-FARA-LVL-05 - 1°-4° of adjustable Caster correction - 3/16 Construction, Fully Internal Gusseted with 1/2" Additional Tire Clearance - Limit Straps Kit Included - Serviceable 17-4 Stainless Spherical Joint at Frame Connection for longevity and bind free Cycling - Combines with Radius Arm Drop Brackets for 4.5"-5.5" Carli Systems - Fitment: 2005+ F250/350 4x4 - In Depth Look SKU: CS-FHMSS-17 - Inside the Carli Stainless Stabilizer - Long Lasting Performance and Appearance - Bolt in Replacement for OEM Stabilizer - Fitment: 2017+ F250/350 4x4 - Works on leveled and lifted trucks ONLY SKU: CS-FLMSS-05 - Inside the Carli Stainless Stabilizer - Custom Valved for Larger Tires, Adjustable Nitrogen Pressure - Includes Differential Guard and Clamp DATE ACTIVITY DESCRIPTION QTY RATE AMOUNT - Combines with HighMount Stabilizer for Opposing Setup - Fitment: 2005+ F250/350 4x4 - Optimized for Carli 2.5"-5.5" Systems Truck Accessories Labor to install EVenture System 12 120.00 1,440.00T Truck Accessories Alignment 1 99.00 99.00T Truck Accessories Alirlift 7500XL 1 629.00 629.00T Truck Accessories Airlift Wireless Compressor 25980EZ 1 619.00 619.00T Truck Accessories AIR LIFT COMPANY (ALC) 52420 Spacer for lifted Trucks 1 79.00 79.00T Truck Accessories Labor to install Airlift system 5 120.00 600.00T Truck Accessories S&B 10-1004 60 GALLON REPLACEMENT FUEL TANK FOR 2017-2022 FORD POWERSTROKE 6.7L CREW CAB SHORT BED 1 1,249.00 1,249.00T Truck Accessories Labor to install 2.50 120.00 300.00T Truck Accessories Window Tint All Around Windshield Ceramic 1 380.00 380.00T SUBTOTAL 17,125.00 TAX 1,532.69 TOTAL $18,657.69
