Great discussion.
@Raspy @Modman and
@MrFancypants have great inputs in their discussion points. There is a tradeoff no matter which way you convert, and it will always require more energy, every time you convert. It just presents itself in a different form.
What is failing to be discussed is wattage. All energy can be converted to wattage for a neutral comparison. For example, 8.5A @ 120V is 1020 watts. 50A @ 12V is 600 watts. But here is the missing link in the discussion, overall system efficiency. Assuming 10% loss for every conversion, the max wattage out for an AC inverter with the above specs would be 918 watts. (However,
[email protected] would be 1207 watts) To get the same wattage out of the trucks 12-volt system without any conversion, would be 76.5A. (Using 12 volts standard for comparison) To get that same power through a DC-DC converter would be (again, assuming 10% loss) is 84.15A. Now, throw in the efficiency of cable loss. If you run 84A through a long cable, the cable would have to be ginormous to reduce inherent loss due to resistance. However, if you run 120V through a long cable, the loss is minimal compared to the DC loss. (I=E/R where I is current, E (or V) is voltage, R is resistance of the wire. Watts is IXE.) But you pay for it with the conversion losses of the inverter/converters.
As I said earlier, it always takes more energy to produce less energy. The tradeoffs are usually cost of materials and efficiency of the converters. There is no free lunch.
A sine wave inverter for conversion generally requires more energy to run than a modified square wave inverter. Modified square wave converters can be cheaper, but the efficiency can be unbelievably inefficient, as high as 35 percent loss.
The output voltage of the sine converter is far superior to run sensitive devices. So, the tradeoff: cost of the inverter for better "device" efficiency with the sine inverter and cable expense. Don't forget, the AC conversion is actually DC to AC, then AC to DC to charge batteries. Twice the conversion loss of a DC-DC converter.
Always use the minimum number of converters and best wire for better efficiency in your setup.
A DC-to-DC converter is a necessity if you want to charge with the trucks 12V DC on a separate battery to maintain the charge within the designated specs by the battery manufacturer. (Especially true if running Lithium batteries) The tradeoff: heavier wire for better efficiency and minimum cable loss, cost of the wire, some loss in the converter requiring more current to be drawn than the total output. You would also require such a device for solar. (Voltage regulator)
Beware the marketing math associated with the sale of inverters/converters. They are typically marketed with unrealistic real-world specs. The questions should always be how many watts are required for your desired needs. This will then be the point where decisions are made for the type of system that best fits your setup. What's the efficiency of the converters, what kind of batteries are you using, how long do you intend to run the wires, will you have access to a generator, house voltage, shore power, and other connection issues that will be part of the equation.
If you are not familiar with all of the items discussed here, you should always consult with an installation/sales
expert before making a decision on how you want to wire your trailer or toy hauler.
As always, hope this helps.
