I'm not a guru at this stuff, but with a big honking alternator (and often two) mounted under the hood, why not hook up any "sump" batteries through an isolator and charge them off of the ac system. Wouldn't this be much more efficient and faster than charging through a dc/dc charger with its incumbent losses?
I have a similar setup for my auxiliary battery in my Land Rover. When truck is started, once voltage stabilizes both batteries are linked and charge as long as engine is running. IF I wish, at camp I can flip a switch and disconnect the auxiliary battery from the starting battery, or the isolator automatically disconnects them if the voltage falls below a certain threshold to protect the starting battery. My solar is also integrated into the setup to charge the auxiliary any time the sun is out.
This setup also gives the option to link both batteries any time for things like self-jump starting or winching.
Just a thought.
Just a thought.
