DC to DC charger
100% agree with this, believe you could charge a lithium battery with the alternators direct and they be okay. When the voltage gets too high the internal BMS will shut them off not the best but would work in a pinch. This was my idea too as my Lithium’s are mainly solar, but I wanted the ability to run a set of jumper cables to charge them if it wasn’t sunny for 10 days.
The issue I was told however from the friends that did it are the lithium batteries low internal resistance. This means that 400Ah of batteries would draw at 1C placing 400A of current on the alternator overheating it in 30 min at cruise speed even quicker at idle. The reduced draw of the DC-DC inverters saves your alternators by killing your wallet. Was bummed to hear alternator could overheat at capacity.
You can do it in a pinch, but abusing Lithiums that way is not a good plan. It's best to not give lithiums more than 14.5, so if the truck voltage starts out higher than that, wait until it drops a bit and then connect. Lithiums don't need a float voltage either, and Lead acids do, so the charging system never stops sending power to the lithiums if charged from a truck . It's OK to do it in a pinch, but set it up right and it will always work well without damaging the lithiums.
You will not overheat the alternator doing this. That is false advertising by Victron. The amps are limited by the wire size and length. Imagine the amps that go to a working winch and that doesn't hurt the alternator. An alternator running at a good speed will not burn itself out.
It’s too late tonight but tomorrow morning I’ll take some photos of the battery management system on my off road caravan and show how It and the truck are wired.
This is the electrical set up I have. The van runs 2 x 300 AH lithium batteries charged either by 240 volt mains power (up to 15 amps) or via a dc to dc charger. There are nearly 1500 watts from the roof mounted solar panels. If, when the van is parked in the garage, a separate solar panel can be plugged in via a red Anderson plug. When under tow, power is supplied by a grey Anderson plug from the Tremor. The Tremor runs it’s own dc to dc charger and 2 x 100AH lead crystal batteries mounted in the tub. It can take power from the alternator or from a solar panel via an Anderson plug.
I‘m quite impressed by the quality of the electrical work they did in the van. All top quality equipment from my research so I’m hoping it will give a long, trouble free life.
Having used Battleborn batteries and attempting to charge them with my previous truck (2017 F-150) and my current truck (2021 F-250 Tremor), I can share this with you.
There is no danger of alternator damage, regardless of which alternator option you may have. It simply will not charge due to the lower voltage of the vehicle. Battleborn (and other lithium) like 14.2 to 14.6 volts to charge properly. This will never happen through the 7-pin connector.
Since I didn't want to modify my truck or the wiring, I went with a Victron 18 Amp DC-to-DC Charge Controller. The OEM wiring is 10-guage, fused for 30 Amps and will easily handle 18 Amps. It works flawlessly and was easy to set up. I installed the DC-to-DC Charge Controller in my camper.
I chose Victron since I am using Victron components for Solar Charge and Battery monitoring. It is also the most flexible and easy to configure of any of the brands offered, at least in the USA that I am familiar with.
Clarification point, one post mentioned the "Victron Network" and the ability of the DC-to-DC Charge Controller to be a part of that network. That is not possible at this time, it could very well be added in a future update to the Charge Controller but as of 2 weeks ago when I installed the Controller in my new camper, it wasn't.
Are these the specs for the OEM wiring going into the 7-pin connector or are you referring to something else?
They are the specs for the wiring on the truck going into the 7-pin harness. Also, on the trailer side the ground wire and the 12 VDC wire are typically 10-gauge. They were on my previous camper and also on my current camper.
Not to change the subject but... @Frazior how'd you mount that breaker? The Dirt Church ARB compressor mount uses a similar breaker but they call for it to be taped to the top of the battery.
Sorry I haven't replied sooner (didn't see the post). I undid the nut on the battery hold down and ran the battery hold down nut through one of the of the fuse mounting holes and then put the nut back on. On the other side I used a nut and bolt with enough washers on the bottom side to allow the fuse to sit flat on the battery.
Just read through the thread so I apologize if I missed something, but I am looking to connect a 4/0 (yes you read that correctly) for an ACR that will charge our 640Ah of lithium in our camper. The ACR will pull between 150-200amps from the factory battery. This truck is equipped with 397amp alt.
My question is if Ford prefers to pull from one battery over another. Driver side cable length is significantly shorter so that would be preferred but it seems like most are pulling from the passenger side battery.
As a Victron distributor I know and love the Orions but frankly increments of 30Amps just aren't going to cut it for this build.
Thanks in advance.
Thanks in advance.
Since the two batteries are tied together in a parallel configuration, there is very little difference between the two for a load connection. Admittedly, there is a miniscule amount of resistance in the wire that connects the two but should be insignificant. I wired most loads to the passenger battery because it has more connection points and nearest to the upfitter switch harness. But the loads will still draw from both batteries.
Anybody hook up a dc to dc charger to their travel trailer. I was t looking at getting the Victron 30 amp or even 2 x 30 amps so I can charge going down the road. I already have a victron set up in the e trailer so it would not be to hard to integrate. Or even put a couple batteries under the bed cover and use them as a “sump” so I can get a charge while out for the day and hook up the bed batteries to the trailer at night?
I've done it on my last two trucks to charge my lithiums in my trailer in addition to the solar system. My current truck, is a Tremor with dual batteries, and the trailer I set up was an Xplore X22 with 480 AH of lithium batteries and 660 watts of solar. It already had a GoPower solar MPPT charger. I ran a #4, two conductor, tinned, marine romex wire set from the passenger sire battery to the rear bumper. There is a 60 amp marine circuit breaker next to the battery. At the rear bumper I mounted a 90 Amp style Anderson plug. On the trailer I ran the conductors back to the battery box to a Victron dc-dc charger mounted in the battery box (isolated style, not designed to share a ground with the truck). The Victron is triggered by increased voltage from the truck when the engine starts, not from a switch. It only has two wires. It also has bluetooth to monitor the batteries and to set up the values for lithium charging. This is an excellent system, but it does have one glitch. The Victron cannot communicate with the GoPower so each sees power from the other and interprets that as fully charged batteries. This means I need to run the Victron at night or in bad weather, but not in full sun. A fix is to install a Victron solar MPPT charger to work while communicating with the Victron dc-dc charger. Be sure to use Anderson style plugs as they are very good.
My current trailer, a Roamer 1, has 1240 watts of solar and 1080 AH of lithium. It has an induction cook stove, 12 volt air conditioning and a 12 volt compressor fridge. I'm also installing an electric water heater. It is great to have a supplemental charging system for the batteries in an off-grid trailer.
Lithium batteries can be charged directly with 12 volts from the truck, but it is not a good idea to do so. They should never see voltage higher than 14.6 and they do not need a float cycle. They also need to be disconnected when the truck is not running, or the truck batteries can be interpreted and a load. The dc-dc charger takes care of all of this and makes it automatic.
When you get a Tremor with only one battery, you get the passenger side battery. And if you have two batteries, the second, or driver side battery is harder to connect loads to. The winch is connected to the passenger side battery. The batteries are connected together in parallel, and it probably doesn't matter which one runs the auxiliary charging line to the dc-dc charger, but it seems clear that Ford sees the passenger battery as the primary battery.
The 30 amp Victron dc-dc charger is designed to have a 60 amp breaker. The #4 wires seem like overkill, but can handle a 60 amp load, or more. With the Anderson plug at the rear, you now have a fine high amp plug for running other equipment, like an electric jack, portable air compressor, lights, or other things. The wires route from the battery, across at the top of the firewall just under the hood, down to the frame area on the driver side and travel with an existing harness in that area. Then up over the spare tire and out near the license plate, where the Anderson plug is screwed to the bumper.
You guys like spending a lot of money on copper. If you're looking for 500W+ across 30+ feet from your truck, you're better off converting to AC in your truck and then using it as a shore power connection to your inverter/charger in your trailer. If you have a MultiPlus it is ready to do this already and can even blend power from your battery bank and "shore" input to manage bigger AC loads. Then you get the added benefit of onboard AC in your truck as well. I could see DC-DC as a solution for bed campers, but I still prefer AC because of its alternate uses.
Converting dc to ac, in the truck, just to supply the onboard shore power charger in the trailer, does not make sense to me. Where do you put the inverter? And the goal, primarily, is to charge the trailer batteries for any use you want. My trailer has 12 volt dc air conditioning, 12 volt air suspension, 12 volt air compressor, 12 volt compressor fridge, lights, water pump, etc. And I have a 2000 watt inverter in the trailer for any reasonable 120 volt loads. The Tremor already has a 400 watt inverter for charging computers and phones. Whenever I'm out camping and want more AC, the trailer is with me and 2000 watts are right there. Converting dc-ac, so i can plug in an ac charger with smaller wire doesn't make sense to me at all. And if you want to run a heavy load on AC from the truck, the engine will have to be running as we only have a limited amount of battery and they are starting batteries, not deep cycle or lithium. If you want to run a large ac load from the trailer, it is supplied by 1080 AH of lithium that can be re-charged from either the sun or dc from the truck. The truck does not have to run at the same time. I like buying copper when it saves me from buying a large inverter and then finding a place to install it.
You make good points @Raspy but I think it depends on your needs and particular setup. Your trailer having mostly DC your direction makes sense to me.
I went through the mental logic of DCDC charger with an inverter in the trailer, more solar +inverter, Truck inverter and AC, etc. In the end I evaluated what I wanted to accomplish and really it came down to the AC fridge as high priority to me. It was less expensive for now to get a Dometic powered cooler (12V/AC). All the other options were ~2x the cost. Pick your poison, more copper, inverter, etc. There is no free ride...
Upgrading the stock inverter to 1200W means equivalent to 100A (minus some small conversion losses) DC flowing to your trailer over a common outdoor extension cord. Replacing it with a pure sine wave inverter also means you can power sensitive electronics off your truck. You can also replace the stock inverter under the rear seat.
If you have a large battery bank I don't see why you would need to charge from the truck unless it is running. Then you can use BCP or SEIC, exactly how ProPower works.
50 feet of quality 2 gauge wire is going to cost you over $300 for the cable alone. That's more than the cost of a quality 1200W inverter.
Well said. There is no free ride. When I see this argument from time to time, I think a simple concept that people miss is that it takes more energy to produce less energy, no matter how it is derived. The more conversions you make, the more energy required to overcome the conversion loss. If your goal is less copper, then AC at 120/240 volts will have less loss over smaller wires than DC and can therefore be used at longer lengths with less copper. DC requires much larger wires for the same wattage to avoid high loss. So, DC to AC, DC to DC, either one has conversion loss as well as different connection considerations.
Solar has a unique argument because the energy seems to come from the sun free of charge! Well, not really. The expense of the solar panels and longevity, storage battery, materials to make the panels, etc., all play into the energy loss argument. But they are very convenient for in the field use.
When camping, efficiency is a key factor to success with solar and batteries. I have a mantra that says that usage will always rise to meet capacity and so far it seems true. When camping I absolutely do not care about what it took to produce the solar panels, I just care about how well they work in the field. Same with my lithium batteries. I do not carry a generator, but I can camp in the middle of the desert, with the AC running, ice cold beer and full internet service 24/7. Solar is a game where all inefficiencies, should be taken into account if you want to have good performance from a reasonably sized system. For instance, inverters are only about 90% efficient, and have stand by losses even when doing nothing, if left on. Compressor refrigerators can double or triple their load if turned all the way down to the lowest setting. Heating water with electricity instead of gas may or may not be good management of resources. And never plugging in, while having all the luxuries, is fun. I don't plug my trailer in. It is off-grid.
My new trailer seemed over the top with 1240 watts of solar and 100 AH of lithium, but here I am cooking with induction and installing an electric water heater. As well as being careless with the inverter, leaving Starlink on all night and running the AC on 12 volts. Yep, pretty soon, usage will rise to meet capacity.
To me, it's false economy to try to save a bit on wire size to enable an inefficient machine to work on a different voltage. Converting 12 volts to 120, just so I can run smaller wire to convert it back to 12 volts at the battery is not interesting to me. That costs and extra 10% of the energy twice in the process. It's similar to the solar panels in that I don't care if a small additional charge for wire enables a lifetime of more practical use. And also, having a high amp 12 volt plug on the back of the truck means I can run my 12 volt electric jack, or auxiliary lights, or a compressor, or a small winch. If I want 120 volts for some outside project, the trailer has 2000 watts available any time, all charged up from the sun, or assisted by the the dc-dc charger.
Efficiency certainly matters, but I would hope charging your trailer off the truck will be an exception rather than the rule. I carry a generator solely for emergencies and my reasoning behind an onboard AC inverter is to ditch the portable generator. While in transit, the rooftop solar can power everything, so at most I would need to run it 1-2 hours to get enough power reserve to make it through the night. And if your plan is to not idle the truck, I’m having a hard time understanding why you wouldn’t just increase the size of your LFP bank instead.
If you’re really a hardcore off grid glamper it’s surprising you don’t switch to a 24V or even 48V battery. 12V is not the right system for high power applications, if for no other reason than safety. Don’t get me wrong, I run AC off a 12V inverter too, but not all day every day and I still cook on propane. All it takes is a DC-DC converter, Oh wait I started off saying you shouldn’t do that ;)
The only time I run the dc-dc chaarger is while towing at night if the batteries are not fully charged. It is not a method for charging under normal circumstances. Practicality does not mean perfection. There is no way I'm going to rewire my entire system just so I can run 24 or 48 volts and save a tiny bit while being incompatible with the world. Practicality is not perfection. It's having less equipment that does more. It's traveling light, but giving up nothing. It's eliminating unnecessary losses. I suppose we all define that as we see fit. It's about having an adequate amount of power with a minimum amount of hardware and hassle. The goal is not to have every tool under the sun, but to work toward the goal of fixing anything with nothing. It's not just with power. I've significantly improved the water system in a number of ways, without increasing tank size, that have made living in the trailer a lot better.
I know very little about how electricity works but am trying to learn more. I recently installed a full Victron setup in my fifth wheel and put in the 30a DCDC charger. I've yet to run the wires in my truck but you got me thinking. The question I have though is; if I replaced the stock inverter, run that to a plug with dogbone adapter to the secondary AC input on the multiplus ii...then that same electricity gets converted back into DC...you're getting (close) to the same amperage put into the battery back as what the alternator puts out. Am I following this correctly? If so, what kind of amperage does the alternator put out? Would it be able to supply a full (or close to it) 100a that the 1200w 120v inverter handles? If that's the case you could theoretically put 100a instead of 30a into the battery banks. That's a savings of 12.6 hrs to charge a 540a battery bank.
