Cut-Out relay for winch power
  • OP 🔹 OP 🔹 FT_Guest3342
  • Start date Start date
Anyone found a good place for the relay on the passenger side? I think that’s really the last piece of the puzzle I am struggling with. I don’t think there is enough slack in the positive wire to the winch controller for the couple spots I have thought of and I would really rather not reroute them to the driver side battery.
@SomethingRandom did you get the warn kit installed? And @FT_guest3342 wasn't there a link somewhere for the relay that you used, swore I had added it.
I found this on in the amazon question section regarding the WARN kit. "This is AMETEK SAS-4214 solenoid, with Carry/Make/Break current ratings at 100/600/200 Amps." Not a 100% on what those terms are referring too but is that warn solenoid strong enough? And then would you still put in an inline fuse with the solenoid for extra safety?
I haven’t installed it yet. I didn’t like my options on the passenger side. I found a nice spot on the drivers side but haven’t rerun the cabling yet. Not planning on adding a fuse or circuit breaker. Stock it’s a direct run to the battery.
Yeah, I have the 7.3 so I have some extra room. to mount was wondering if the rating on that warn kit was high enough. their site doesn't even list winches as a use so just wanted to make sure that solenoid would hold up.
I’ve settled on right behind the air intake about as far to the passenger side as you can go. Seems to be holding fine after a short drive today. Not really any room for it to move after fastening all the wires and having it nestled in there.
Is that the warm kit? How’d you attach the solenoid?
No it’s the same parts as OP (I think) not the warn kit. It’s currently just nestled in there and I’m not convinced that’s a bad way to go.
I'm also waiting for my truck to arrive. I decided to pick this up:
Instead of using the included switch, I'll use an upfitter to energize the winch. By the time I source the 450a+ solenoid, wire, terminations, wire boots separately. I figure I'm not saving much.
Same vendor also carries this:
Which will work well for snugging the hook up against the fairlead as opposed to keeping it hooked over on a tow loop.
I also used the warn solenoid kit. Here is a video of the overview of my up fitter switch install for the winch cut off.
or check out my post on my wiring https://www.fordtremor.com/threads/project-heyfool.13122/post-273635
Does anybody know a good place to get power from to make a relay hot only when the truck is running? I want to run outlets into the bed for my fridge/freezer & power station. I don't want to use one of the upfitter switches because I want it to be automatically on, not dependent on my bad memory.
I do believe that in that bundle of upfitterwires under the hood, there is also a wire that’s an accessory wire. Not certain but I would start your search there.
Happy with your placement? Any issues? There is not much room on the passenger side and this was the spot I thought of as well. Maybe I’ll put Velcro or something in there to attempt fastening it.
No issues at all so far! I did wrap the bracket with some electrical tape to keep it from scratching anything but that’s all. Definitely happy with it so far.
So I got my warn relay mounted above the battery using the hood down rod.
Any reason this is a bad idea? I have aftermarket winch and wiring so I have enough length to make it work. Looks like plenty of room to the hood as well. Any thoughts are appreciated. I’ll wire it another day
