Cut-Out relay for winch power
  • OP 🔹 OP 🔹 FT_Guest3342
  • Start date Start date
If not for things like winches, what do you propose to wire to the upfitters…what are you saving them for? Just curious what other cool toys you’re thinking of.
I personally don’t like the idea of energizing the winch unless I specifically want it turned on. And I definitely don’t need to use it every time I drive the truck.
My winch came with a manual switch that I put under the hood and I use that for now. I’ve been looking at relays and found a 500 amp on Amazon for $60 with good reviews but haven’t bought yet. Which specific relay are you looking to install?
When it comes to the relay, my truck hasn’t arrived yet so I haven’t gotten to the point of buying a specific relay.
FYI there’s two threads covering what folks are using their upfitter switches for so I recommend checking them out:
From that second thread, here’s what I’m considering for my upfitter switches:
My truck hasn't arrived yet, but here's the things I'm considering (will need to reduce down to 6 switches at some point):
I'm also waiting for my truck to arrive. I decided to pick this up:
Instead of using the included switch, I'll use an upfitter to energize the winch. By the time I source the 450a+ solenoid, wire, terminations, wire boots separately. I figure I'm not saving much.
Same vendor also carries this:
Which will work well for snugging the hook up against the fairlead as opposed to keeping it hooked over on a tow loop.
New Tremor owner (2021 Star White Lariat 6.7L w/ Winch) here, first post even.
Beyond the vandal angle, there's another big reason to look at doing this: In an accident, the winch leads can get damaged, shorting the battery and causing a fire. I'm actually a little shocked that Ford didn't do this from the factory.
I'm planning to use the Warn kit for this, since I have it sitting around from another project.
Now I just have to find a few extra cubic inches in the 6.7l engine compartment (incredibly packed already) to put the solenoid ? My initial thought is to use a battery hold down from Off Grid Engineering and drill/tap it for the solenoid in the kit. Then I can keep the jumper short, and it's right next to the upfitter leads.
Does anyone know on a factory installed winch if there is slack to be gained in the positive wire? Looking at it today, the winch is wired to my passenger side battery, but haven't tracked the wire too far yet.
I started looking at this again. So far no, there doesn't seem to be enough slack. Additionally I was unable to find a good mounting location for the solenoid on that side of the engine bay. I also have a 6.7. the best place I could find to mount the solenoid is on the driver side. There are two tabs that were what the upfitter relay box used to mount to before they moved it. It's to the right of the coolant tank and just north of the driver side battery. This is where I'm planning to install the solenoid. I'll also reroute the winch power cabling over to the drivers side.
I wonder if there are a few inches extra to get the solenoid on top of the battery, mounted to the battery tie down. I need to look at it more today.
Thinking if so, one of these drilled & tapped for the solenoid might be the way to go. Then, it would just be a short jumper to the battery, and right by the Upfitter switches.
I just don't know if there is enough clearance from the hood 🤔
Disregard, the OGE tie down isn't an option with the factory batteries, as they aren't sealed and have caps that would interfere.
It looks like the solenoid might fit on top of the battery, but would have to splice in another 6-12" of length to the winch lead. 🤔
Highly suggest you check out the upfitter guide posted by Ford BBAS for Super Duty trucks. I don’t there is enough clearance above the battery for that.
  • Like
Reactions: ccw
Definitely, without mocking it up, best case is it will be close. I also found a spot right near the airbox, but that will require me to cut/splice the winch lead to sneak it in back there.
Is there something I am missing about the upfitter switches? One of the 25a circuits (would go to a much smaller fuse, even) should be more than ample to run the solenoid?
Upfitter guide isn’t referring to the upfitter switch documentation. BBAS stands for body builder advisory service. Ford publishes documentation for companies that upfit vehicles for special purposes (police cruisers, bucket trucks, etc). They include among other things under hood clearances.
Yes the upfitter switches that came on your SD will all be overkill to run the low power side of a solenoid.
Ford BBAS: https://www.fordbbas.com/publications
2022 SD Guide: https://madocumentupload.marketinga...4f2a9dc16b11a696cd10141db8a36a8da090&v5=False
Maybe you can find some space down where the winch contactor is placed. There are several voids in the bumper and you will have to have the bumper off to install the winch anyhow.
Maybe. I'd prefer a disconnect much closer to the battery and out of an impact zone line like that, though.
This is incredible! Thank you for sharing!
Question for you guys that may be more electicricly inclined than myself. I have a 500amp continuous duty solenoid. Is there any reason that I cannot switch the main ground rather than the positive on the winch? I have done ground switching relays in the past for horns etc. I cannot think of any reason why this would not work. There is plenty of ground cable to make it to a spot just on the fender well next to the cowl on the passenger side. Which is conveniently right next to the Upfitter wiring. Hopefully you guys have some input.
From all of my reading I’ve been doing in preparation for accessory wiring for my own truck (read: not an expert) it should be fine functionally.
The biggest reason I can see to putting the relay on the hot side is extra protection in case of a short to ground on the positive wire (e.g. in case of an accident). If the solenoid is on the positive wire close to the battery, the positive wire after the solenoid will be a completely dead wire most of the time rather than live.
This is particularly relevant in the case of the Ford winch since, as far as I could tell looking at the instructions and the wiring under the hood, there is no fuse for the winch. Normally that fuse would protect the wire from a short. If you fuse the positive wire then that concern is essentially gone (though redundant safety measures never hurt anyone). Personally, I will be adding a fuse to the positive winch wire as well as a solenoid.
I'm think that I will just put in a manual battery disconnect on pos side of winch connect when I get winch. Lift hood make connection use winch disconnect when not needed.
Which disconnect are you considering?
Being I have a 6.7 there is a main issue I have with using the positive side. There really is no room for a disconnect or a solenoid on the passenger side in the front or under the battery. There is a small spot in between the battery and the air box. The problem is it would be real hard to service the filter.
I would move the cables to the drivers side but I’d like to keep my install as factory looking as possible and still be able to activate with an Upfitter. I followed the factory install sheet to a T. Minus the fact that I trimmed the center bumper trim to fit. Which created a license plate problem.
If you guys have a fuse solution I would love to hear it. Provided that it will handle the 300/400 amp load current and is compact enough to fit. not a whole lot of room in the 6.7 engine bay.
Here's a 600A fuse holder and 500A fuse to go with it:
Should be pretty compact.
Thanks. Didn’t realize mega fuses went up that high.
  • Like
Reactions: ccw
Indeed! That site makes it super easy to filter down to a fuse that will work. Just go to fuses and set the current rating to 500A (or whatever you want).
Find the fuse that works, then go to Power Distribution -> In-line Fuses (or fuse blocks) and set the filter to the type of fuse you chose. Pick the fuse holder of your choice. :)
