Dealer replaced coolant control valve did not fix problem what tells the ecu to open and close this valve sensor in the transmission? Anybody solved this yet?
Given the input of the outside air temperature (OAT), the passenger mirror mounted temp sensor might be a culprit. Otherwise sounds like you might be good to install a block heater.
Not sure how you are getting to operating temps on the transmission after 8-12 miles in 20*F temps That's f-n amazing. Likewise I can't see it taking 60 miles or 1 hour "so it shifts right".
Are you driving 1 mile to work?? How much driving are you doing daily?? Why do I ask....cause it matters QUITE a bit to how the transmission functions along with the PCM.
I know not all people are "happy" with the way Ford transmission shifting works or is "programmed" to work. I for one wish people would learn more about these transmissions. I can tell you once an owner learns what's happening, you learn it's all operating just fine.
Biggest issue : For one it's WAY too difficult to make the shifting function great for ALL purposes and ALL people at the same time. There's a give-n-take situation sometimes which leads engineers to make a decision about how to get the best results for performance and product longevity. Sometimes owners need to "give a bit more pedal" instead of being a ol' maid driving to church.
I watched one video from a "disgruntled" owner.....he was driving the truck STAYING UNDER 1500RPMS up to 50+MPH, complaining about how it was shifting. People were telling his deaf ears to drive it with a bit more punch. He just didn't hear anyone cause of the wool stuffed inside his ear canals. So this "issue" wasn't a transmission issue at all, it was an owner issue plain as day.
Are there transmission issues?? YES....I'll never argue there are no issues. Is EVERY transmission issue a Ford production/tuning problem......NOPE. How do I know??? Well I'm not just some guy that hangs out here, I drive my truck DAILY. There are times when I ask myself...what just happened?? Then I drive, drive, drive some more....then I see what causes the "issue". It becomes a combination of things of which pedal input and driving conditions (traffic, stop-n-go; road route, turns etc etc) become the #1 and #2 reason for the transmission to "shift weird" or "quirky". I don't mean to sound like it's all on the owner, but I wanted this out there as people search for this topics on forums/internet.
