Agree, I don't think the Wicked solution will work for anyone who needs full articulation. For those who lift their trucks and are only driving on roads, their solution accounts for the added lift height, and it seems would give a similar range of articulation as the OEM design provides at factory heights.
Basically, if you're a mall crawler or use this for work/commutes, the Wicked solution is likely fine. If you're doing the types of off road runs that you do, then I don't know if their solution work
We're still working on them, but yes, they're underway! We thought we had a solution, and we do for the front, but the rear is a different animal in adding the amount of travel we have and eliminating the factory block; thus changing the height of the sensor mount and extending it's usable range. We had them on a truck through several offroad trips, then i took it out to our local desert to test something else and partied hard enough to break both rears. If it can't survive me in a Dominator, it's not ready for the market.
The scales will never work. You're changing the spring rate and there's no way to change the algorithm that calculates drop to spring rate to calculate the load. This isn't a huge deal to us as the scales only function when static and most agree it's a gimmick that's not worth maintaining at the expense of the ride quality. Our goal is to optimize the headlight function, but ensure they're aimed properly for the 3.5" and 5.5" lift to not blind oncoming, loaded or unloaded.
Their solution is simple. With how complex ours is to ensure the travel works, I can't imaging theirs would last one trip on my truck. I've not tested it, but have thoroughly tested a solution that outtravels theirs and it didn't work. That said, I can't offer anything better at the moment, so take it for what it's worth... LOL
Do you all have something just for the front ? I need only fronts on two f350 platinum srw. Mainly for the headlights auto adjustments not scales,not rear. In rear I just used 2019 f350 srw blocks etc to level truck .I hate to drill holes in radius arms if you have something Carli I can purchase that will work
