- OP 🔹
- #41
If your factory steering is in perfect working order, there's no benefit unless you're running extended travel and are at risk of damaging your drag link. I've run factory ford tie-rods well over 100K miles without requiring replacement, but the drag links are another story. I go through them every 20K-30K miles at $460 each from the dealer. That said, I push my rig on 38" tires.@BLACKCHERRY what would you see as the benefits for Tremor running 37x12.5x18 with just 1 inch lift?
What you're describing as a kit, I think is amazing. Changing to a forging process along with the attention to detail retaining serviceability by alignment shops is incredible.
Looking forward to seeing the product released, thanks for the update.
This system adds far better joints that are rebuildable (vs. replacing the linkage entirely). Longer service life, more joint travel for extended travel capability without inducing joint wear, better materials and finish, and stronger joint design to handle larger tires and off-road forces.
