Building "Gus" (aka DD/Adventure/Camper Tow Truck)
I currently have the same 35x17x12.5 tire size your are pondering with the Toyo RT Trail's and came from the same stock setup you now have. I like the tires a lot generally but my seat of the pants evaluation is that the sidewalls, while being larger, also seem pretty stiff even at around 50 pounds of pressure? I don't tow heavy and may be trying something else next time.
I also got rid of the 5100's as they were much harsher than the Falcon 1.1's that came with my Readylift level kit. The Falcon's don't hold up (am on warranty replacements now) and will be upgrading those shortly.
I played around with the front end today to emulate the front lift from the springs. I'm sort of hoping to be around 1" or less. Based on another member here, his Center Hub to Fender measurement is 25" (but he's diesel & has a winch), but still, if I ended up at 1" higher, I'd be pumped!
My goal is to stay with 35s, not 37s, so I am hoping for minimal lift. If I need to, I can pick up a Tremor block for the rear, but I'd rather not if I don't have to.
I'm not going to contribute anything meaningful to the suspension conversation, but I do feel like I need to comment on the "velvet hammer". This is giving me volvo with a gun rack type thoughts and I'm sitting here trying to find a way to caricature an actual Velvet Hammer to be used as a graphic on the truck.
I used one of those AI prompt things:
Also, purple because it's the color of royalty.
Yes! I'm interested in this too:
For a daily driver I would definitely install the Carli Rear Shackles and Torsion Sway Bar. Start with 55/50 psi in the tires and adjust to your liking.
I would also go straight to a 2.5” shock of your choice. These trucks are heavy and a 2.0 shock is not enough.
If you are sticking with a 35” tire, the Tremor Front Springs (off a Gas Motor truck) are a good option. 1-1 1/2” lift and better ride. I am building a Long Bed Tremor and don’t want a higher lifted truck and I will go this route. (Plus, I have the springs as fresh takeoffs from my 24 Tremor) I will also install the Tremor Wheels and 285/75/18 Toyo ATIII Tires.
I agree with these! All that is on my list. I think I will have to look at PMF for the torsion sway because I've been told the Carli version won't work on stock height.
I was going to get Tremor 4800 gas springs, but for the money, I decided to go with BDS 2" progressive lift springs. Based on some other's measurements, I'm thinking they will be about 1-1.5" of lift - hopefully. They should also ride smoother being progressive.
I'm definitely planning to move to a 2.5 shock, it's just a couple steps away. I've got Bilstin 5100s now and I enjoy doing a step at a time to see each incremental step.
Carli shackles are for sure on my list! Thanks!
Go to CJC Offroad website, they install many many Carli systems. Carli even sent me there to confirm fitment of there product on a stock truck. Watch the video that is on the Carli Sway Bar page. It’s stated repeatedly that the Torsion Sway Bar will work great on a stock height vehicle.
Okay, good to know. I mean, I didn't really understand why it wouldn't work, seems somewhat adjustable. Good to know. I have a friend with a RAM and said it was night and day!
I have the Torsion Sway Bar and The Rear Shackles on my 24 Tremor and it is night and day. Especially for a daily driver!
I did not see a Gas Motor Version of the BDS 1-2” Springs? Diesel only.
Yep. I called BDS and their level kit for gas contained those diesel springs...she said it might be a 1/4" taller or something. We'll see. There's a guy on here that has a diesel with those springs and his fender to hub gap is 25" and mine is the same with the snow plow springs (which I bet are the same for gas and diesel). SO, my HOPE is that it won't lift the front much at all, but will be softer.
My goal is to soften the truck up as much as possible, keeping it as close to stock as possible and keep the truck on 35s.
In the end, I may just end up full Carli with 37s lol - At least I'll have some data points for others looking to soften their trucks too!
Putting the Carli shackles & swaybar on my list! Probably right after 35x12.5R17s...
I would not recommend a Diesel Spring in a Gas Truck. Too stiff!
Understood. I would no recommend these snow plow springs either! I BELIEVE these BDS springs will be even softer than Tremor gas springs. So 'made for diesel' or not, I'm gonna try these.
Just ordered these two items. Here we go.
BDS 2" springs (hoping for 1-1.5" lift)
BDS alignment cams
Do you want to sell your oem tremor coil springs?
For what it's worth on my 250 non-tremor: I have a 1" BDS level (puck, not springs), 1-7/8" rear blocks (reverse leveling setup), 18's with 37's, run 45F/40Rpsi for unloaded highway driving, with Fox 2.0. It rides pretty darn smooth for unloaded. With a +18 offset, I had 0 rubbing or trimming.
It improved even more when I installed my RSI Smartcap and added a couple hundred pounds of gear in the bed (so it's not riding 100% unloaded).
UPDATE!
I FINALLY got my wheels & tires! I'm in love!
Stock:
Snow Plow package
Camper package (rear swaybar)
20" wheels (275/55R20)
Now:
Bilstein 5100s (meh) ($400)
BDS 1-2" lift springs (diesel on my 7.3L) ($225)
Rough Country adjustable track bar ($200)
Toyo AT3 37x12.5R17
Method 305 17x8.5, zero offset (slight rub on mud flaps near full lock with a bump/body roll)
The truck really rides great at 50 psi, still need to chalk test the tires to figure out the proper inflation. The truck is basically level if not 1/4" nose high, but I really need to measure on flat ground, my driveway is deceiving.
Best part?! It still fits in the touchless car wash by my house!
Got to drive the tires in the NC snow last weekend at Beech Mtn and they did great!
I took my time, read a LOT, looked at even more pictures of wheels and I'm stoked with the results.
Next up:
- I ordered S&B radius arm drops (on order, to get to 5-6 degrees castor, currently at 0 castor and it's not terrible) and want to run the S&B alignment specs.
- Chalk test the tires
- Figure out my airbag situation (more on that later, but I talked to Dave at S&B about a 'blow off valve' for the bags)
- Save up for either Fox 2.5 HTO or Performance elite
UPDATE!
Stock:
Snow Plow package
Now:
Toyo AT3 37x12.5R17
Next up:
Any pictures with the BDS Front Coil Springs installed?
Here's a photo with BDS 1-2" springs installed (they are technically for Diesels). I was really happy with the height and stance. The ONLY issue is that I felt like the rear needed a little rake - especially when towing.
I recently swapped out to Carli GAS front springs and am even happier!
BIG UPDATE!
As of November 2026, I made the following changes.
Left - Old setup (BDS/stock height)
Right - New setup (Carli/Tremor height)
Swapped BDS 1-2" springs for Carli GAS 3.5" springs.
These springs are EXACTLY the same height as the BDS springs (Diesel, no gas part number) and they definitely ride a little better. It seems like small bump and bigger bumps they feel softer. I am still running my 'stock height' Bilstein 5100s, so I am probably limited on full range of travel and it can still ride even better! Will replace those soon.
Carli rear shackles
These are noticeable. The rear end feels softer and feels like it 'moves' better when the suspension cycles. I do hear a little squeak when I go over speed bumps...no big deal though.
Added Tremor height blocks
I wanted some rake back and it was suggested to do this with the Carli springs. I really like the stance of the truck with these and should help keeping level when towing my 10k camper
Removed rear air bags
I may regret this, but I removed these because I rarely NEED to use them. So far, the rear suspension feels WAY better because my truck would hit big bumps (think man hole covers, pot holes, etc) and it doesn't bottom out the bags. Before, when I hit those bumps, I would get a sharp hit felt in the seat that would sort of pogo me in the truck. It's the type of hit that my wife would look up from her phone and make a comment. Now they aren't noticeable. I will tow my camper later this week and see if I regret this at all.
23+ 2.5" Trailer Hitch - to carry a 37" spare!
I scored a 23+ hitch from a local junk yard and swapped it in. It bolts right in and I should have made some measurements before of the stock spare, but there seems to be more room on the left and right side to add a bigger tire. At some point, I'd like to just see if I can fit one of my wheels in there...
I also tow a triple axle toy trailer and do not use air bags, hardly ever hit the overload springs (and I don’t think you need them with your trailer) on my stock Tremor F350.
Air bags are pretty easy to remove & reinstall if needed. (But add the Daystar cradles).
Change the fronts springs, shocks, tires & wheels to gain more sidewall for small bumps as you have stated. Also drop the tire PSI when not towing/empty.
And use an adjustable track bar. 🏆
But yes, the snow plow springs with 20” rims & tires are killing your ride. 👎👎
And here I am hitting the overload springs with my TT. 🤣🤣
My bed is filled though 🤣
