Building "Gus" (aka DD/Adventure/Camper Tow Truck)
dpspeed
Tremor Buff
Winston Salem, NC
2020 F250 7.3L
I've been lurking on here for a bit with my non-Tremor 2020 Godzilla. I picked up this truck because we bought a 36' camper in July 2024. The camper is a 8200lb (10k loaded) Grand Design Imagine 3250BH.
We've had the truck for a little over a year and it LOVESSS to tow the camper. The Godzilla & 10 speed pulls the camper wherever I've asked it to go. Our first trip last year was from NC to the UP of Michigan. We had a hurricane coming in on the way back so we left St. Ignace, MI at sunrise and drove 15 hours home and the truck did so well that I could have driven another few hours without being totally ready to get out from behind the wheel. It's a joy to tow with!
Daily driving...this is a different story. Coming from a F150, it's quite a bit stiffer. I KNOW I KNOW - I bought at HD truck. The ignorant will just say 'deal with it.' I'm not planning to do that :) I drive most of my daily commute in Winston Salem, NC and the roads near my house are terrible. Potholes, manhole covers & patched pavement. It's so jarring that I don't drink coffee until the highway. It's so bad my wife and kids comment regularly that they miss Gloria (that was our F150).
My plan is to turn "Gus" into a 'do everything well' truck. My plan is to actually keep the truck as close to stock as possible without getting into lots of suspension mods. I also plan to run 35s since I do not want to mess with carrying a 37" spare.
Current setup:
- 80k miles on the truck
- Snow plow package (stiffer front springs)
- Camper package (rear swaybar)
- Bilstein 5100s (meh, they didn't feel much different from stock)
- Weigh Safe True Tow Heavyweight – Weight Distribution Hitch
(for towing camper)
- 20" BAP wheels with 275/65R20 (ouch! stiff) (45psi unloaded, 65psi towing)
- Airlift 5000 air bags (might swap out for stock bumpstops)
- Alibaba aluminum shell
Planned mods:
PHASE 1: More sidewall, softer front springs and more compliance with airbags
- BDS 2" progressive lift springs & caster adjusters (hoping to only lift 1.25-1.75" over stock, which would probably be 1"+ over Tremor springs)
- 35x12.5R17 tires (Nitto Recon Grapplers - 34.4" / Falken AT4W 35" / Toyo AT3 34.4") - also these tires are roughly 65# each
- Method 703 17x8.5, 0 offset - 26#
- Daystar cradles for airbags (hoping to gain back some compliance)
Honestly, if this really softens things up, I may not go to phase 2. Time will tell! Oh, I may also need an adjustable track bar, but maybe not.
PHASE 2: More Cush from high powered shocks
- Fox 2.5 DSC rear shocks (want the adjustable to stiffen for towing and soften for daily driving)
- Fox 2.5 HTO or DSC front shocks (may just go HTO to save money & less complexity)
- Fox 2.0 TS steering stabilizer
Day I bought it with 62k miles
Ordered an Aluminum Shell on Alibaba, took about 3 months & was $1700 shipped from China to my door. Pretty happy with it for the price. Really wanted a GFC topper, but it was $5k+ and just didn't want to sink that much money into it.
How it currently sits! STOCK snow plow suspension + BAP 20" wheels and 34" tires
It tows things (2021 Grand Design Imagine 3250BH)
Picked up a 'project car' with my neighbor's trailer (SWEET aluminum trailer)
When not hauling the camper, it mostly hauls bikes. I'm also working on a 'wheel on' setup INSIDE the bed because I don't want my bike to get stolen. This setup is to haul the whole family's bikes.
Looking forward to documenting this journey!
More sidewall
I had driven many SuperDuties prior to getting my Tremor and was pleasantly surprised with the ride quality. I think the extra sidewall of the 18" wheel/35" tire has a huge impact. If course, aired to an appropriate pressure! Good luck with phase 1 :cool:
For your daily driving as long as your not carrying a load if you aren’t already take your tire pressure to 50 psi up front and 45 psi rear and check that out. Sulastic or Carli shackles on the rear springs might also be a beneficial reasonably inexpensive change.
Personally I’d pull the airlift bags off your rig. They are adding to your daily drive harshness. If your only using the Weigh Safe HD hitch vs a weight distributing hitch your missing out on some suspension and sway control benefits there. With a weight distributing hitch setup I doubt that they (the airbags) would be actually impacting your towing ride much at all.
The front progressive rate BD springs you are contemplating will likely give you the best bang for your buck beyond what I’m suggesting above. That snowplow package makes a normal stiff ride in an F350 much harsher! Be prepared the improvements will be marginal at best as there is a by design difference in how an empty 150 and 350 feel no matter how much money you throw at it.
🤞 I think sidewall is gonna be my biggest ride quality mod.
The springs and 20's are what's giving such a harsh ride unloaded. Or at least a major contributor. I had the same thing.
I would also skip the bags. Had them too. They definitely affect the ride unloaded.
You'll likely want an adjustable track bar. Drop brackets are OK, but to get the thrust angle right in an alignment the adjustable is usually better.
Good luck and post some pics!
Yeah, thanks for pointing these out. I updated the original post.
45psi unloaded
I have the Weight Safe WDH heavy weight hitch
Might get Carli Shackles, pretty cheap & easy install
Hoping for some softness from the BDS springs! From research, progressive lift springs should help a TON with front harshness. I also think the front stiffness contributes to the rear bucking - but we'll see.
Airbags may indeed come out. I don't 'love' the airbags and don't use them very much. I've actually found that when I use them they make the truck really stiff on the interstate. Also, if I do end up with 2.5 DSC rear shocks, I think the adjutability will help me dial in ride quality while towing as well. The trailer tongue weight is only about 1100-1200, so it squats about an inch.
I may also need to grab some Tremor rear blocks, but I want to wait and see how the BDS springs settle. If I start with a little rake, then hook the trailer, I may have no need for airbags. If I do keep the airbags, I could see the cradles helping since I think some of the bucking I feel is from the airbags hitting hard (down travel) and bucking (limiting uptravel).
One thing to consider since you have a 250: add in a set of F350 overload springs. I kinda wish I had done that with my old truck instead of the air bags. Our trailer is 1400- 1900 on the tongue depending on how its loaded (toy hauler). The adjustability of the bags was nice, but I think I could have adjusted the WDH tension to achieve the same level stance of the truck. Then unloaded ride would not change.
You could probably find the springs and hardware fairly cheap.
Many of us have a good experience using with a set of Timbrens instead of airbags. Much simpler solution - both install and usage. I've found they are transparent when not towing and add just enough stiffness to offset sag and settle the truck when towing, without being harsh.
Just my 2 cents ditch the air bags, put Timbrens on and the Carli shackles. I also did Accutune 2.5 DSC shocks. The Timbrens don’t make contact till the overload springs do, so no effect on unloaded ride. Add a factory sway bar. Run the DSC unloaded at 2ls & 4hs and when towing go to 4ls & 7hs truck is rock solid towing. Coming from a dually this thing is pretty solid towing.
I and a few others stand by my earlier post comment in this thread to ditch the air bags as a major improvement to softening your daily drive ride. But at the risk of going off topic (but related as I debated a separate thread) just a bit I’d like to offer the following modification up for debate.
I personally believe a full air suspension system provides the softest possible ride. But I’m also not wanting the full 4 Link lifted look or the significant expense, as a personal preference. I hate the idea of spending close to $6K for larger tires, wheels and adjustable shocks that are IMHO only going to get me marginal ride improvement. So what is an alternative? My research and gear head logic has pointed me to the Air Flex Suspension System for the Super Duty Truck. The advantages seem clear, which are:
* Auto Leveling capability at all times (loaded or unloaded)
* Adjustable “on the Fly” stiffness
* Bed / Tailgate dropping for easier loading and unloading
* Very Cost Effective at approx $4200 for the whole system (plus install cost)
* Towing “Sway and Body Roll Control” benefits
I found this video of the product that has some very impressive ride harshness improvements which has really peaked my interest, I invite you to review:
So now the big question: Anybody on this forum have any experience with this product and what say you about its performance? Seems like it could be the way to go!
If I was going to spend on a total suspension I would look at this system.
I haven’t seen much on this system since the thread about it around 18 months ago. It does appear to be technically advanced but at over 4 times the cost of the one I’m asking about it makes you wonder if it’s worth it.
I just put a levelling kit on my XLT which meant 4 new shocks (Fox) and new 35's and I was pleasantly surprised at the softer ride.
I've looked at this site and there's basically no information or pricing. Interesting, but man, looks complex. I want the truck to stay as close to stock as possible. IDK, a killer Youtube video could change my mind though lol
From my research, I believe you're right. The bags came on the truck when I bought it, so I'm inclined to keep them as a control at the moment. I have the stock stuff, I could pull them off and probably will as a 'free' mod to see how it changes the ride.
I REALLY like the idea of my truck mods being front springs & shocks (and maybe an adjustable track bar) AND larger sidewall tires.
How do the 2.5 DSC shocks ride on a daily basis? Seems like you can dial them in to be super plush to stiff and anywhere in between. I might opt for 2.5 HTO front and 2.5 DSC rear...I might run 5100s up front and 2.5 DSC rear just to see how each axle feels. Science + budget lol
Really like the adjustability of the 2.5 DSC ran them at 0 front and rear was really soft, am up to 2ls & 4hs and truck rides great. Here’s a picture of the clearance between Timbrens and the bump stop.
Just ordered these two items. Here we go.
BDS 2" springs (hoping for 1-1.5" lift)
BDS alignment cams
I believe the least expensive approach ?? would be to replace the 20" wheels with 18's with a quality set of American made 35" Tires. Install a Carli Torsion front sway bar and a set of Sulastic rear Spring Hangers. At this point consider Shocks. Keep in mind the Shocks you choose for a truck that tows or carries heavy loads are not the same as a truck that is mainly used as a second vehicle. I suggest considering an adjustable/variable rate/dual reservoir style designed to combat the increased heat generated when under load.
I also tow a triple axle toy trailer and do not use air bags, hardly ever hit the overload springs (and I don’t think you need them with your trailer) on my stock Tremor F350.
Air bags are pretty easy to remove & reinstall if needed. (But add the Daystar cradles).
Change the fronts springs, shocks, tires & wheels to gain more sidewall for small bumps as you have stated. Also drop the tire PSI when not towing/empty.
And use an adjustable track bar. 🏆
But yes, the snow plow springs with 20” rims & tires are killing your ride. 👎👎
I currently have the same 35x17x12.5 tire size your are pondering with the Toyo RT Trail's and came from the same stock setup you now have. I like the tires a lot generally but my seat of the pants evaluation is that the sidewalls, while being larger, also seem pretty stiff even at around 50 pounds of pressure? I don't tow heavy and may be trying something else next time.
I also got rid of the 5100's as they were much harsher than the Falcon 1.1's that came with my Readylift level kit. The Falcon's don't hold up (am on warranty replacements now) and will be upgrading those shortly.
