Pick any two:Go ahead with your recommendations
Best
Cheap
8" lift
Hope you find what you are looking for!
Saw that, but it says for diesel only.I copied/pasted a cheap 7in option from ready lift. You can clear 38s with 4in so I would assume 7in would work with 40s
Makes no differenceSaw that, but it says for diesel only.
This whole topic is dumb, he refutes suggestions, dosent seem to want advice.Makes no difference
Spring rate is slightly stiffer
Nobody makes gas options
Looks like the BDS 8" option is going to be the best. @ $4500Makes no difference
Icon has a few options tooLooks like the BDS 8" option is going to be the best. @ $4500
Ditto!No offense, or maybe take offense at this, but that truck looks like crap, if the look is what you're after. Maybe forget that idea and if your money is burning a hole in your pocket, give it to a food bank. Better use than crafting something that just looks wrong. IMHO, of course!
This is the look I'm going for...
Yep will have to upgrade all the front u joints, steering stabalizers and with the driveline angle involved maybe even need some double cardigan driveshafts....To each his own. I would definitely upgrade the brakes though. The Unsprung rotational weight of 40s will have a huge negative impact on braking as well as every component of the drive train
Looks like they have some kind of bolt on fix for the front driveshaft so it will work...this looks fun.....wonder if re indexing prevents oil from getting to all parts that need it...Looks like the BDS 8" option is going to be the best. @ $4500
These trucks are meant to tow up to 20,000lbs. I highly doubt an extra 25lbs of tire weight is going to do anything man! I mean come on now.To each his own. I would definitely upgrade the brakes though. The Unsprung rotational weight of 40s will have a huge negative impact on braking as well as every component of the drive train
