Best & Cheapest 8 inch lift kit for 40's?
Looks like they have some kind of bolt on fix for the front driveshaft so it will work...this looks fun.....wonder if re indexing prevents oil from getting to all parts that need it...
"The new front driveline design requires correction when installing the 8" lift to retain use of 4WD at any speed. To do this BDS supplies a high strength transfer case indexing ring specific to the 8" systems to rotate the front output of the transfer case down to improve the front driveline operating angle. The indexing ring uses ARP studs and includes new mounting hardware. BDS also supplies a heavy duty replacement transmission crossmember and new transfer case mounting bracket for additional clearance."
Relocating and extending brake lines is also mentioned nothing on correcting rear driveline angle....yep this is great "bolt on and go kit"
I saw that in the fine print. The more I think about this, the more issues I see arising with 8in+ lift. I'm leaning more towards 38's and a 6in lift now. I just want a bolt and go setup.
These trucks are meant to tow up to 20,000lbs. I highly doubt an extra 25lbs of tire weight is going to do anything man! I mean come on now.
Look up the effects of rotational mass. It is not just 25 lbs of weight, there is a whole lot more to the physics of it than I care to explain
This guy seems to already know all the answers. Why waste your time trying to help when he dosent want help or advice. I don't believe he is legit anyway.
  • Like
Reactions: Gus
If I was building a race car or truck and planning to track it, then yeah I might be a little concerned. But this is a 7,500lb giant 8 lug pavement princess truck. A slightly bigger, heavier tire is not going to do anything in my case. But thanks for the concern!
So I guess we shouldn't modify our trucks? The rotational mass of a 40in tire might be to much for the heavy duty truck to handle. lol
To each his own... But why spend the money on the Tremor package if you're going to do all of this to it and it's not going to see any dirt? None of the electronics that you get with the Tremor package will be of any benefit at this point.
What electronics? A locking rear diff and "rock crawl" mode?
If you want to do it the right way I would suggest talking to PMF Suspension in Tucson. You are definitely going down a rabbit hole and starting from a position of a limited budget. Good luck trying to achieve your dream ride. My guess is all in for the cheapest 8” lift on 40s is going to cost you at least $10k
I was planning on 12k to do everything right. However, at that point, it's just not worth it to me. I just wanted a more aggressive stance for the truck and I think that can be achieved with 38s and maybe a 4.5" to 6" lift that doesn't require any other modifications.
  • Haha
Reactions: Gus
Just do a Carli System then. You can find lots of builds from them on this forum - from mild to wild (shocks w/ electronic dampening changes on the fly). Just search Carli in the search bar
Nobody is trying to be a jerk to you, we are simply trying help you make a smart, safe decision.
When someone uses “best” and “cheapest” in the same sentence, it’s usually not good.
When you’re driving a monster truck on public roads, you definitely should be concerned with safety.
There is SO MUCH that really should be done to do this properly.
And a 40 isn’t a “slightly” bigger tire. I don’t know if you have set one next to your stock tremor tires, but a 40 is massive
Probably still going to have to relocate and replace factory brake lines. Any lift above 4" is rarely bolt and go.
I wouldn't worry about running 40's with the stock braking system. Back in the 80's and early 90's guys were running 40's on vehicles with braking systems far far less robust than these trucks have. I'm not aware of anyone hurt or injured because of it. Shoot, 40's are the new 35's nowadays. There are plenty of Super Duty builds using 38's and 40's, from no lift to over 8", I have not seen braking system upgrades to be a necessary part of them. If this was an 84 Toyota we were talking about, then maybe a brake upgrade might be something to consider, even then, not entirely necessary.
That indexing ring is just a 1.5 or two inch spacer like an aluminum donut that you put in between the shaft and the transfer case. All it does is move the shaft forward so the splines have more bite on each other. Only downside is that the angles become too steep and you get noise in 4wd. It's easier and cheaper than pulling the shaft and getting it lengthened.
As you’ve seen, the majority of folks on this forum have a focus on practicality. :) But it’s your truck, so I say go for it!
(Caveat that you’ve already addressed: go for it as long as you aren’t towing or hauling even moderately, as then safety becomes a big concern. If the truck is just for hauling people and some luggage around, then you’re good to go IMO.)
My only thing I want to make sure you’re aware of is the potential reduction in ride quality on-road. Driveways, expansion joints, potholes, speed bumps, etc.
CJC has a great video about it that I can’t find for the life of me. Guy put thousands into an 8” lift for his Ram, hated the ride, then replaced it all with a Carli 6” lift.
If you’re OK with a potential ride quality drop on pavement, then not much I can help with but I hope you get the look you want!
So a cheap spacer fix instead of adding a the correct lengh DS with a CV joint...gotcha.I though since they are providing new mounts and crossmembers they were changing the angle of the transfer case must just be to make room for the donut......so you get an 8" lift and 40" tires and maywork 4wd....sounds awesome...
  • FullSizeRender.MOV
    12.4 MB
I know, it's the wrong way to do it. Personally I always got my drive lines lengthened and balanced. Shops do this so the whole lift can be installed completely in 1 day for customers. And it's cheaper.
“ Best” and “cheapest”. Never go together in the same sentence
