with a 2 battery system on your truck you have 2 batteries connected in parallel
connect the battery tender however you want, but if you don't connect directly to the battery terminal & you don't connect the positive lead off the battery tender to the positive terminal of one battery & the negative lead of the battery tender to the negative terminal of the other battery you are not maintaining both batteries.
if you have your battery tender connected any other way besides this way and you have never had an issue.
it's because you drive your truck enough to not need a battery tender anyway!!!!!
if you don't do as i say??????
hope you're never stranded just because you didn't listen!!!!!
